Setting points on 1955 Sea King (Gale...
Old Marine Engine » Timers, Magnetos, Ignition » Setting points on 1955 Sea King (Gale) 22 hp « Previous Next »
Jess
Posted on Friday, May 13, 2005 - 11:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What is the proper way to set the points if you don't have the special gauge mentioned in the service manual? This is a two cylinder motor.
Post Number: 502
Posted on Saturday, May 14, 2005 - 08:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You need to set the points to .020 with the points at the high point of the cam. Set one set and then turn the flywheel 180 degrees to set the other set.
Doug Daniels
Posted on Monday, August 01, 2005 - 11:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am looking for a Carburetor rebuild kit for a Sea King (Gale) 3.0hp motor, also a carb. Throttle Valve and Level Assembly (P/N) 591028. The model number is GG-18735 and the Serial Number is 16X833811.
Please let me know the price and availability.
Thank you
Doug Daniels
Post Number: 538
Posted on Tuesday, August 02, 2005 - 07:15 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Doug,
You will have a much better chance of finding what you need by posting a free want ad in the Pre 1980 section of our outboard classifieds. Here is a link
http://www.marineengine.com/cgi-bin/suite/classifieds/classifieds.cgi?request=di splay_sub&category_id=108&website=default&session=42ef55293c2278aa
