Make-N-Break
Old Marine Engine » Boats with Early Inboards » Make-N-Break « Previous Next »
Dylan Eisenhauer
Posted on Sunday, July 28, 2002 - 01:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I came across a 1.5 hp make-n-break, and I have most of the parts but the ignition system, and a part that bolts on ahead of the governer, I think it operates the throtle. I found an old make-n-break coil, but like I said I don't know how the old ignition system operated. I can't find any diagrams or anything, so any info is useful, even links to a web site that I might not be able to find. thanks.
Posted on Sunday, July 28, 2002 - 01:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dylan,
If you can supply a little more information maybe someone here can help. Do you know who made the engine? How do you know it is a 1.5HP?
The make-n-break ignition worked basically the same on most of the early one lungers... but each was slightly different. If you can identify your engine maybe someone can post a picture of the identical parts.
The Palmer Gas Engine Handbook shows details of the early Palmer make-n-break ingition with good detailed drawings, as well as wiring diagrams that would apply to any make-n-break engine.
If you don't know who made the engine you could post pictures here and someone might be able to identify it for you.
Regards,
Andrew
Dylan Eisenhauer
Posted on Tuesday, August 06, 2002 - 11:30 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
it is a fairbanks - morse, ,, I know it is 1.5 /hp because the name plate is on it, it has 3 differnt patent #'s but they are dates. I live right by Lunenburg Foundry, and I went into the archives and they are sending me a copy of the origional manual, that doesn't really help me with how the Governer operates the throtle. It does have a Carb, I was talking to a guy on the weekend that said that they weren't all carborated. "?" I don't know about that,, but he is passing my name along to some of his friends because they have a couple old ones like mine and they can't get them to run so I might be able to get a few parts pretty cheap. I will try to get the patent dates written down the next time I am at the shop. Thanks Andrew
bill
Posted on Tuesday, August 06, 2002 - 12:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
here is afm make and brake, but it is on a 7.5 hp cylinder.Text description
Joe
Posted on Wednesday, August 07, 2002 - 11:46 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dylan on the East Coast; If your engine has a governor than I doubt very much that it is a marine engine. Something you said has caught my interest.....Lunenburg Foundry has info and manuals on Fairbanks Morse. I have a Canadian Fairbanks Morse single cylinder two cycle marine engine of about 2 hp. Do you know if they have a manual for this engine? ....Joe on the West Coast
Dylan Eisenhauer
Posted on Saturday, August 10, 2002 - 07:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Well Bill that doesn't look like mine at all Actually mine looks like the stationary engine, but my grandfather said it was in a boat."?"
Joe, I'll tell ya what! I'll give you the address for the foundry, and you can write them and ask for the specific engine that you are looking for. Mine is a Model Z 1 1/2 H/P. it is classified a "Throttling Governor Engine" It "HAD" yes HAD a type R high tension rotary magneto. Weather or not that tells you anything, I don't konw,, all I know is that I still can't find any parts, yet that is,, I was talking to a guy whos friends have them all together but can't get them to run, and everything works,, and he said they might sell them cheap. I like that word when it is antique! :)
Lunenburg Industrial Foundry Engineering Ltd.
P.O. Box 1240, 53 Falkland street.
Lunenburg. Nova Scotia. Canada, B0J 2C0
Phone (902)634-8827 FAX (902) 634-8886
I hope that might help you out! but get as much info on your engine before you call fax or wright.
bill
Posted on Sunday, August 11, 2002 - 10:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
model z fm are a very common engine, made by the millions. you are on the wrong web site, you should be on http://www.enginads.com/smokstak.cgi
and to find an ignitor go to http://www.oldengine.org/members/brookover/ignitor-list.htm
model z were introduced in july 1914, and the type r mag was introduced in late 1924. these engines are still made today, for use in oil fields, although not made by fm.
go to this page, http://www.oldengine.org/members/christison/links/
and scroll down and look at all the fm engines, there must be 25 of them, and see which one looks like yours.
post the serial number, and i can tell you the year it was made, and from that i can tell you a lot about your engine.
Dylan Eisenhauer
Posted on Friday, August 23, 2002 - 05:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bill do you want the number in the top of the casting for the cooling jacket? if so I can look for it,, I haven't been able to get looking at it lately because of work,, but I guess you can't have toys to play with if you don't have the money :)
Bill Schaller
Posted on Sunday, August 25, 2002 - 11:43 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
dylan, did you find any that look like it? go ahead and post the number on the jacket, it should be the sn , and then i can date it.
Ira Dorey
Posted on Tuesday, September 03, 2002 - 10:41 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi,
I have a 5hp Acadia in my 20' motorboat.
There is a crack at the back of the water jacket and water seeps out when she's running, not a lot, just enough to put off a little steam.
Is it safe to run the engine like this, it still runs perfect and gets lots of water.
Also, can I get the crack welded?
Hoping to hear from you soon.
Ira Dorey
Little Burnt Bay, NF
