Irreducible
Old Marine Engine » Boats with Early Inboards » Irreducible « Previous Next »
marks
Posted on Thursday, September 25, 2003 - 04:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here a couple of pictures of progress so gar on my latest project, the Irreducible.
It is meant to be finsished for the Davistown Putt Putt Regatta so there is still a lot of work to be done.
irred1
irred2
irred3
9 Days to go!
regards
Mark S
Posted on Thursday, September 25, 2003 - 01:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mark,
Looks great!!! Nothing like a deadline to get a project finished.
Regards,
Andrew
John Kemister
Posted on Thursday, September 25, 2003 - 06:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Mark, what engine are you going to put in it?
Hope you get her completed in time!
Best of luck.
John
marks
Posted on Friday, September 26, 2003 - 04:00 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Andrew.
John its a Baby Vinco. We hope to have the boat finished Sunday. The big problem is going to be painting and varnishing.
Cheers
Mark
peter ogborne
Posted on Friday, September 26, 2003 - 07:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mark , a beautiful job . Having joined the ranks of the boat owners [ wooden] i will be calling on you blokes for advice and helpful ideas . I have bought a 16ft boat " Juno". I have a selection of engines to put in her but i think i will opt for the Stuart Turner P5
marks
Posted on Saturday, September 27, 2003 - 05:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Peter,
Juno is she Carvel, Clinker? I don't own a Stuart but everyone thinks they are pretty good even the people who only like the Oz engines concede(privately) that they are a good engine. Maybe even on par with the Simplex.
God I'm "bugggard". When we bored the shaft log it went in and came out at the right spot, but it had a half inch curve in it. Should of set up a boring bar rather than using an auger and my home made chaser.
To fix it we had to make up a six foot long rasp. A piece of 3/4" gal water pipe with hundreds of slot cut in by a sharp cold chisel.
Unfortunately my helper fell ill and went home today which will set our plans back by two days.
And I thought wooden boat building was a relaxful spiritual experience.It has been until the deadline of the Davistown Putt Putt Regatta.
Anyway the Irreducible will be there even if I have to row or be towed.
Regards
Mark S.
peter ogborne
Posted on Saturday, September 27, 2003 - 07:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Carvel, Mark . She has a small half cabin which of course houses the engine . I was going to get her out of the water early next week but my helper has to rush of to Perth and i have to go up at the end of the week. Juno came with a good tandem axle trailer . We will float her on to it and i will get her home and do some work . Main job is to get an engine into her.
I have an option on a small vee steam engine which i may install at a later date .
Boring that hole for the shaft does not sound fun !
Posted on Saturday, September 27, 2003 - 08:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Anyone who enjoys the Irreducible, and missed this link before, should see the pictures of Brad Shipp's boat at the following link ...
marks
Posted on Tuesday, September 30, 2003 - 09:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sounds Good Peter,
BTW try not to let her dry out too much otherwise you will be at best waiting a while for her to swell up again or at worst recaulking.
Good luck with the engine.
Mark S.
marks
Posted on Tuesday, October 07, 2003 - 07:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
We got a few coats of paint on at about 4am the day of the Davistown Regatta. We did not finish the thru hull bits for the cooling system.
Our plan was to go over with two pieces of hose hanging over the side for cooling.
After a couple of hours sleep we got the boat ready to go. The engine wouldn't start. After a lot of running around we managed to borrow a trailer and took the irreducible over by road.
Despite lots of trying during the day the engine refused to start.
We still have quite a bit of painting and varnising to do. Some Pictures below.
irred
irred2
irred3
irred5
irred7
As a footnote the day after the regatta we cleaned out the fuel tank and used new fuel. The engine ran perfectly.
Regards
Mark S.
Steve OBrien
Posted on Thursday, October 09, 2003 - 08:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Wow thats fast work, MArk.
Would love to see some pictures from the Putt Putt regatta. MAybe I'll get there next year.
Posted on Thursday, October 09, 2003 - 09:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You did a great job Mark.... the boat looks wonderful. Be sure to post pictures of it running!
Regards, Andrew
marks
Posted on Monday, October 13, 2003 - 09:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks,
I'll be taking a couple of weeks off boat building to attend to some of the more mundane chores that have built up lately.
I'll post some pictures of launch day.
Mark S.
Paul Bunch
Posted on Tuesday, November 04, 2003 - 07:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mark, I was thumbing through the WoodenBoat, 'Fifty Wooden Boats', a plans book. The introduction was followed by an article from Weston Farmer discussing the boat IRREDUCIBLE. I did a search and ended up here. Fantastic job on your boat. I think I am interested in building this boat. I do not know were to begin to obtain an engine for this boat similar to the one installed on your boat. Could you possibly provide leads as to where one might be obtained. I would also be interested in the number of hours you have building this boat. Thanks in advance for you help.
marks
Posted on Wednesday, November 05, 2003 - 10:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Paul,
For the engine it depends on where you live. Small inboards are relatively easy to find in Australia.
I'm not really sure how long the build took. I tried to do a couple of evenings and a Sunday afternoon a week over a fourteen month period. Although there were many weeks I couldn't and other weeks where I did a lot more.
My best guess would be @350 hrs. The next boat I build will be much quicker as I now sort of know what I'm doing and will not procrastinate as much.
Basically I started this to gain the skills and tools for a much larger restoration project. I'm now about to have a garage sale for about 80% of the tools i purchased as I find I do not need them.
BTW Paul if you do build the boat there is an error in the offset tables. I'm not sure if it is deliberate as i believe Weston Farmer used the irreducble as a lofting exercise in one of his articles.
Best regards
Mark S.
whitfield
Username: whitfield
Posted on Wednesday, September 15, 2004 - 05:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a boat made by the "Canadian Boat Company" but cannot find any info to authenticate it or verify it's model and year. Can anyone help me please??????
bruce
Username: bruce
Post Number: 224
Posted on Wednesday, September 15, 2004 - 08:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Whit, Look for the Peterborough Ontario based Canadian National Canoe Heritage Museum for starters. This is based in the old Peterboro Canoe factory. They should be able to put you into a network of their connections to help solve your riddle.
