Brennan four cylinder.
Old Marine Engine » Multi Cylinder Gas Inboards » Brennan four cylinder. « Previous Next »
Ned Lloyd
Posted on Thursday, September 09, 2004 - 07:39 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Would anyone know where I could find a picture of what a Brennan four cylinder engine looks like? I am told they were built in Syracuse N.Y., and is supposed to be about half the size of an atomic four & weigh about 160lbs complete. I think it has an iron block, aluminum head & pan(?) Thanks.
bruce
Username: bruce
Post Number: 220
Posted on Thursday, September 09, 2004 - 10:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hang in there Ned while I try and locate my Brennan File or better yet; contact the man I obtained the file copy from at [email protected]
Ned Lloyd
Posted on Friday, September 10, 2004 - 07:32 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bruce, thank you, I will try your contact. I am curious what they look like & would like some info on them. - Ned
Moderator
Username: andrew
Post Number: 896
Posted on Saturday, September 11, 2004 - 04:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
See this link from a previous discussion.
Also try the search function on the board.
Post Number: 547
Posted on Tuesday, September 14, 2004 - 10:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
1906
B
Ned Lloyd
Posted on Wednesday, September 15, 2004 - 02:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank you Richard!
bruce
Username: bruce
Post Number: 223
Posted on Wednesday, September 15, 2004 - 08:41 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ned, The Brennan 4 cyl I think your illuding to is the Brennan IMP.Some were Crosley based and some were actual Brennan derived cast iron blocks. These were 50's era auxillaries of 25HP.How did you make out with the reference I gave you?
Ned Lloyd
Posted on Monday, September 20, 2004 - 03:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bruce, not too well. He has a six cylinder Brennan that is over 100 cid. per cylinder & didn't mention any info on smaller ones.
Post Number: 567
Posted on Monday, October 04, 2004 - 08:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
1941
bimp
