Post Number: 1654 Registered: 01-2002
| Posted on Tuesday, May 07, 2013 - 04:54 pm: |
Early DuBrie Somewhere I have information on this engine. When I find it I will scan it and post. It is tiny flywheel is 9 inches Good compression and complete original, I think. I suspect it will run.
david_doyle
Member Username: david_doyle
Post Number: 11 Registered: 03-2013
| Posted on Tuesday, May 07, 2013 - 09:06 pm: |
Very smart looking engine. Really like the looks of the ignition timing. Is that some kind of advance retard lever on there? Thanks for posting. |
robert
Post Number: 564 Registered: 07-2003
| Posted on Wednesday, May 08, 2013 - 01:30 am: |
Yes, cute little unit that. A good wipe down and some boiled linseed oil to bring up the paint? |
Post Number: 1666 Registered: 01-2002
| Posted on Wednesday, May 08, 2013 - 09:30 am: |
Yes the timing advance and retard is the lever on the aft end of the crankshaft. And no intent to paint it just clean it up as you suggest. I found the info on it and need to replace the primer on top of the mixer with an oiler.
Post Number: 1668 Registered: 01-2002
| Posted on Friday, May 10, 2013 - 06:14 pm: |
Scans of info from Cycle and Automobile Trade Journal ca 1905. I have this info as a PDF however this is the best quality I could do with my scanner in the JPEG mode.
Post Number: 3027 Registered: 11-2001
| Posted on Friday, May 10, 2013 - 10:24 pm: |
* Stanley DuBrie is one of a rare few early engine designers and mfgrs that his history deserves a Book wriiten of his life ! He graduated engineering school 1896 and sold his fisrt marine eng in the same year !That Company was sold and by 1900 he designed an automobile engine for Charles Beck Mfgring Co.Of Penetang,Ontario. A short time later he designed a marine engine for Peter Payette also of Penetang,Ontario. 1904 he teamed with the Caille Bros to design and mfgr a Twin automobile engine. 1905 finds Stanley in Detroit and incorporating another entity the DuBrie Motor Company that mfgrd the engine in the above post,I have seen a photo of one of his first 1905 engines it had a six spoke counterbalanced flywheel, all other photos have the solid wheel ? 1906 DuBrie Marine engine ad
1906 Gray Motor Company ad
1907 the engines got away from the pedestal base mounting, drip oilers fed into cylinder, and they started using the Toquet Oscilating timer.
1907 Several models were available
Post Number: 2739 Registered: 01-2002
| Posted on Sunday, March 30, 2025 - 09:50 am: |
So here it is 13 years later. Yes it runs good. |
