Build date of Fay & Bowen S/N 1133
Old Marine Engine » One and Two Cylinder Gas Inboards » Build date of Fay & Bowen S/N 1133 « Previous Next »
mdusk
Username: mdusk
Posted on Sunday, September 17, 2023 - 09:21 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Recently acquired an old launch with a Fay & Bowen single cylinder S/N 1133. Two different opinions about the age of the motor. As well as the hp rating (1.7hp and 7hp). It was built in Geneva, NY with a Patent date of Oct. 21, 1902, and is rated at 475rpm. Anyone know when this motor was built?
Post Number: 2711
Posted on Wednesday, September 20, 2023 - 06:55 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Pics will help. If you have problems posting them click on my name on the left and e-mail them to me and I will post them for you.
Post Number: 2713
Posted on Wednesday, September 27, 2023 - 02:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here are Mark's Pics
Enjoy
narrabay2
Username: narrabay2
Post Number: 264
Posted on Saturday, October 07, 2023 - 12:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Nice! Would be great to see pics of the whole launch too.
andyno
Username: andyno
Posted on Thursday, October 12, 2023 - 06:22 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can you tell me the price of this item on the market? And good luck starting the engine.
nararaandy
Username: nararaandy
Posted on Sunday, June 16, 2024 - 01:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Fay & Bowen engine, no 3632, single cylinder vertical two stroke. Seriously damaged but restorable, unfortunately converted to high tension ignition. Any chance of anyone having a spare igniter or parts for one. I have downloaded to original patent but construction from scratch doesn't look easy. The original gearing on top of the internal sideshaft is intact.
