captjack
New member Username: captjack
Post Number: 2 Registered: 04-2006
| Posted on Sunday, June 11, 2006 - 09:21 am: |
i just bought a detroit 2-53 diesel. it has the blower and runs great. i can not find any information on this engine on line. if someone could aim me in the direction to get imformation on this engine HP Torque and such i would be gratefull. |
captjack
Post Number: 3 Registered: 04-2006
| Posted on Sunday, June 11, 2006 - 09:25 am: |
by the way this 2-53 is not a turbo model it is naturally aspirated |
Post Number: 403 Registered: 01-2002
| Posted on Sunday, June 11, 2006 - 01:08 pm: |
Capt, Marine Engine dot Com has manuals for your engine. You can get to them by clicking here Hope this helps Ernie |
alfred riley Visitor
| Posted on Friday, June 30, 2006 - 11:46 pm: |
all detroit 2 cycle engines are super charged just to make them run |
Post Number: 411 Registered: 01-2002
| Posted on Sunday, July 02, 2006 - 04:06 pm: |
Alfred, I think Capt is refering to lack of a turbo. You are correct all 2 stroke Detroits have a roots blower to scavage the exhaust and push in a fresh charge of air. However it is possible to have a turbo in front of the roots blower. |
| Posted on Tuesday, July 04, 2006 - 02:49 pm: |
the way that gm id's it's engines is to put a t after the cubic inch 2-53T 6V53T etc.if it is turbo charged |
Post Number: 412 Registered: 01-2002
| Posted on Tuesday, July 04, 2006 - 04:22 pm: |
Yup and an I after the T if it was intercooled As in 8V71TI etc |
Justin Logue
| Posted on Monday, June 02, 2008 - 09:58 pm: |
I have aquired a 4 cyl detroit with an irrigation pump on the farm. I work for Caterpillar but do not have two stroke experience. I dont know how to tell if it is a 53 or 71 model. Two of the injectors stuck after the first attemp to start. I would like to replace them and get this unit running, possible for antique engine shows. Can injectors be changed with out special tooling? If not, is this tooling expensive. I have lots of tools, access to even more, just no one around with two stroke detriot knowledge. Any help is greatly appreciated. |
larry_from_maryland
Post Number: 299 Registered: 07-2003
| Posted on Tuesday, June 03, 2008 - 11:35 am: |
Injectors are easy to change no special tools needed as long as you replace with the same number injector. Be sure to get the injector rack ajustment back in the same place and all of them the same. I have freed up many injectors myself without going to a professional. A 53 series engine will have 2 pullys that turn on the front top of the engine. A 71 series will have one pully on the rear top of the engine. Most of the 53 series will have a casting marks CWC on most all of the castings. Trying to type an explanition of the procedure for removeing injectors would ba challenge for me. |
RUDBUOY
| Posted on Thursday, January 22, 2009 - 03:10 pm: |
I am consindering a 2-53 for a boat I have built. I will need to control RPM's with a throttle, but have been told this can't be done with a 2-53. The mechanic telling me this says 2-53's govs. are all for constant speed usage(light plants, pumps,etc) and the 2-53 cant be used as a variable speed unit. |
amos
New member Username: amos
Post Number: 3 Registered: 01-2006
| Posted on Thursday, January 22, 2009 - 05:05 pm: |
I don't think that is accurate because there was at least one application in a 1950's John Deere tractor that was a variable speed unit. |
sherlock
Member Username: sherlock
Post Number: 16 Registered: 11-2008
The 2-53 is used mostly for the light plants and industrial pump units, with PTO's,..but I do show that a Varible Speed governor, open linkage is available, being the same as the 3-53 and it depends on which side of the engine it is. I reccomend that you contact your local Detroit Diesel Dealer/Distributor, that can help you on this and they should be in the Yellow Pages. The 2-53 only has a 2/Valve Head, verses the 3 & 4-53 having a 4/Valve Head, being better for a constant load Marine Engine, but your 2-53 Should work also. Good Luck! |
Post Number: 428 Registered: 07-2002
| Posted on Thursday, January 22, 2009 - 08:42 pm: |
I have a 2-53 on a JD dozer, has throttle control. |
drdetroit
New member Username: drdetroit
Post Number: 2 Registered: 12-2009
| Posted on Wednesday, December 30, 2009 - 07:36 pm: |
Howdie, I have H.P. ratings for you all with 2-53's - with "35" injectors the H.P. is 34 @ 1800 & 36 @ 2000 RPM'S - Valve lash .011 inch cold - Injector torque 25 foot lb. Unfortunatly thats about all the info I got, because our 2-53 repair manual has grown legs. |
bkcc64
New member Username: bkcc64
Post Number: 1 Registered: 07-2010
| Posted on Tuesday, July 27, 2010 - 04:50 pm: |
I have need of a camshaft for a 2-53 model and the end gears as well due to water damage. Any ideas where I might locate parts? Thanks |
2dasea
New member Username: 2dasea
Post Number: 1 Registered: 01-2012
| Posted on Monday, January 30, 2012 - 10:15 pm: |
I have a 2-53 on board for light plant and air compressor. The unit was completely rebuilt by P.O. and then sat for quite a while. I went to start it, fired right up but then wanted to run away. Had to cover intake to kill it. Man it was screaming! I suspect one of the fuel racks is hanging up. Wondering if any of you experts had had this occur and if it is common and easily cured? |
johnoxley
Post Number: 52 Registered: 04-2010
| Posted on Monday, January 30, 2012 - 10:32 pm: |
Had a pair of 12V92s in boat - two blowers and two turbochargers each engine - one engine would not start traced to a stuck shut injector holding all others down. Then very inky exhaust during acceleration cured by DD speeding up gear ratio to blowers. HP proved on dyno. (Boat eventually scrapped by the next owner when crew forgot to unmute low oil pressure alarms. Oil line to one turbo ruptured --> all oil was pumped around the engine room --> destroyed engine.) |
jimmys
Member Username: jimmys
Post Number: 18 Registered: 01-2011
| Posted on Tuesday, January 31, 2012 - 01:31 pm: |
One of your injectors or both are probably siezed from sitting for a long time, or water contamination....Remove your Valve cover and check the fuel racks on your injectors, to see if they move freely, or probably stuck in the full fuel position,..causing your 2-53 to run away, stuck in the full fuel position. You may be able to free the racks, but will probably have to remove the injectors and replace/repair them. Be sure and replace your fuel filters, to get rid of the water in the fuel...the injector tips do not like water and the injector tips will blow out. |
larry_from_maryland
Post Number: 473 Registered: 07-2003
| Posted on Tuesday, January 31, 2012 - 05:40 pm: |
There is a speed control rack under the valve cover,its the shaft or pipe that runs along one side.Tighten a vicegrips on it and try wiggleing it around.Sometimes they will loosen with some manuel encouragement.It needs to be able to move when you move your throttle.If it wont move you will have to remove the ijectors and soak them in diesel fuel.Then useing a plactic or rubber hammer try tapping the meter shafts in and out untill free.This is a common problem if an engine sits without use. |
larry_from_maryland
Post Number: 474 Registered: 07-2003
| Posted on Tuesday, January 31, 2012 - 05:42 pm: |
One more thing its best to wiggle the rack with a vicegrip before you start one. |
kappie
Member Username: kappie
Post Number: 5 Registered: 12-2010
| Posted on Saturday, June 02, 2018 - 06:11 am: |
iffyou like any info about the detroit diesel 353 i have the overhoulbook from some engines |
gunner
New member Username: gunner
Post Number: 1 Registered: 04-2021
| Posted on Monday, April 05, 2021 - 08:56 am: |
I am working on a 2-53 that has been sitting for 1 year and it will barely idle and than dies? How can I get it to speed up? |
Senior Member Username: miro
Post Number: 1130 Registered: 11-2001
| Posted on Monday, April 05, 2021 - 09:03 am: |
I think you might get additional advice from this group on SmokeStack https://www.smokstak.com/forum/forums/detroit-diesel-two-stroke.264/ That group is dedicated to the Detroit Diesel engine. |
