Blaxland Pup weight?
Old Marine Engine » Blaxland » Blaxland Pup weight? « Previous Next »
Andrew Matthews
Username: andrewm
Posted on Monday, December 28, 2009 - 04:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi all,
I've bought a Blaxland Pup which I plan to fit to a 14' fibreglass clinker displacement hull which is currently outboard powered. There is also a shaft and gland, a couple of props and a clutch.
The motor and bits are in Adelaide and I need to get them to Sydney.
Can anyone tell me how much the Pup weighs for freight quotes? The mount looks heavy as well, looks like a display stand.
Cheers, Andrew
neil r jones
Username: senojn
Post Number: 35
Posted on Wednesday, December 30, 2009 - 01:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Andrew ,
Just put the sum of the parts including the clutch on bathroom scales and came up at about 60 kgs. Props are 2 kgs plus each and the shaft being long will pack separately.
Transport costs vary ,say $200-600. Prohibitive?
Try a friend or relative !
Good luck.
Neil
Andrew Matthews
Username: andrewm
Posted on Wednesday, December 30, 2009 - 01:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Neil,
Thanks for going to the effort to weigh the bits.
On the advice of Quinton in a previous post, I contacted Brett Jacobs from Gloucester (Blaxland Chapman) and he said to allow for 65kg so he's right on the money.
I got a quote from www.transdirect.com.au and with the shaft packed as a seperate item and allowing 90kg for the motor and other bits, the cost was only about $85, which is very reasonable for a door to door service between Adelaide and Sydney.
I can't wait to start the conversion into the hull.
Cheers, Andrew
