renner20hotmailcom
Member Username: renner20hotmailcom
Post Number: 5 Registered: 01-2023
| Posted on Friday, January 27, 2023 - 10:48 am: |
Hi All we were attempting to rebuild our 1922 Palmer brothers Model YT1 marine engine however today we discovered 2 large cracks in the cylinder wall, any possible part available to purchase.Thanks |
Senior Member Username: miro
Post Number: 1219 Registered: 11-2001
| Posted on Friday, January 27, 2023 - 03:39 pm: |
I suspect that your best bet will be a dry sleeve. Since it's a 4 cycle engine you won't have to fuss with intake and exhaust ports. Most old school auto machine shops have to tools and skill. |
renner20hotmailcom
Post Number: 6 Registered: 01-2023
| Posted on Wednesday, February 01, 2023 - 11:08 am: |
thanks Miro |
narrabay2
Senior Member Username: narrabay2
Post Number: 259 Registered: 10-2019
| Posted on Monday, February 06, 2023 - 11:27 am: |
The cracks are on the inside wall? I've seen the outer wall of the water jacket repaired with JB Weld. In my case the inside wall was scored pretty bad so I had it sleeved. When the shop bored it for a sleeve, the lower reaches were dark meaning the corrosion was coming through. In your case it sounds like the cylinder might be thin from corrosion and yes Miro is correct the solution is to bore and sleeve it. As long as u have meat at the bottom to form a seal, and the water jacket holds water, you should be okay. If that works, keep antifreeze in at all times to stop further corrosion. If totally failed, I have always thought a new cylinder could be easily made from steel by a machine shop. Two thick tubes, two spacer rings, and a flange and some welding and machining. Keep us updated! |
renner20hotmailcom
Post Number: 7 Registered: 01-2023
| Posted on Wednesday, February 08, 2023 - 10:20 am: |
Thanks Narrabay2 |
flyerboy
Member Username: flyerboy
Post Number: 7 Registered: 04-2022
| Posted on Tuesday, February 21, 2023 - 11:21 pm: |
I have a YT cylinder thats been repaired that Ii have no use for |
renner20hotmailcom
Post Number: 8 Registered: 01-2023
| Posted on Wednesday, February 22, 2023 - 12:17 pm: |
Hi Flyerboy, What type of repair was done?,is it still usable? What do you think you would ask for the price also? Thanks Paul |
flyerboy
Post Number: 9 Registered: 04-2022
| Posted on Wednesday, February 22, 2023 - 10:47 pm: |
Hi Paul, Email me @[email protected] and I'll send you some pics. As far as price, just pay me for what ever the shipping is |
renner20hotmailcom
Post Number: 9 Registered: 01-2023
| Posted on Thursday, February 23, 2023 - 10:14 am: |
Hi Flyboy, Thanks so much, I will contact you at your email Paul |
