junkers mk 65 opposed piston single |
peter dixon
| Posted on Sunday, June 01, 2003 - 08:08 am: |
have engine minus fuel pump.any correspondence welcome |
mechman
| Posted on Sunday, June 01, 2003 - 06:26 pm: |
Goodday Peter Could you give more information---I I'm not up on the model numbers & wonder if this is marine,(aircraft?) how many cylinders & H.P. --Thanks Larry Healey |
peter dixon
| Posted on Monday, June 02, 2003 - 08:34 am: |
larry, this is marine single cylinder engine wih 2 opposed pistons of 65mm bore. combustion chamber between pistons.1 crankshaft,3 bigend journals.bottom conrod on centre one.2long conrods either side up to piston on crosshead on top. 2 cycle operation.12 hp? hope this helps regards peter |
donwhite
| Posted on Monday, June 02, 2003 - 11:17 am: |
Help! I enjoy reading about boats and engines although I never owned one and have no mechanical skills. I have tried mightily to visualize the engine described by Peter to Larry. Only if the single cylinder was bent at say, 150 deg or more, leaving a separation of 30 deg or less, then I could see this 2 cycle engine working if there was a single throw on the crank. But Peter describes a 3 throw crank. Or, what is the 'bottom con rod on the center one' connected to? Help! Don White, Observer from Jacksonville, FL |
| Posted on Monday, June 02, 2003 - 12:41 pm: |
http://www.junkers.de.vu/ > Prof Hugo Junkers was one of histories most inventive and prolific individuals in the early developement years of the internal combustion engine. late 1800's to mid 1930's.> I read some where that he submitted the first patent on an opposed engine mechanism in the early 1900's ? He designed and made many marine engines but I have not found a source for this info yet. > Would also like to see schematic of the above mentioned engine! |
peter dixon
| Posted on Tuesday, June 03, 2003 - 07:54 am: |
ok, will try again. vertical engine, piston on rod on middle bigend,bigends eitherside are on same plane as each other but 180deg. to centre one.2 long rods then go up front and rear of sleeve to a crosshead on which another piston mounted upside down fits down open top of sleeve if bottom piston goes up,top one goes down. injector in middle of cylinder.exhaust port controlled by bottom piston, inlet by top. also rectangular scavenging piston on top of crosshead running in casting on which poppet valves are there for air entry. now you are confused! similar to doxford layout i think regards peter |
donwhite
| Posted on Tuesday, June 03, 2003 - 08:37 am: |
Bravo! Peter, and thanks. I'm still assimilating this, but it is changing from heavy mud to light mud! Is this a possible pre cursor of the Sterling engine? Thanks for your assistance. Don White |
peter dixon
| Posted on Tuesday, June 17, 2003 - 04:56 am: |
no Don, i think not. it appears these engines not too common then and chances of finding fuel pump fairly slim! may have to fit non original one. |
David Reid
| Posted on Thursday, July 31, 2003 - 01:28 am: |
Hi, My wife and I live aboard an old power boat that I am told was originally powered by a Junkers diesel. It was said to be two cylinder, hand start with a huge flywheel. I would love to learn more of these engines. |
Christian Schupp
| Posted on Tuesday, May 04, 2004 - 04:43 pm: |
Hi have a look at my homepage. sorry, in German ;-), but you can look at the pictures, perhaps you can translate it by google.com. my Site about opposed piston engines my Homepage |
raymond
| Posted on Thursday, June 17, 2004 - 06:08 am: |
Peter Dixon, I see your engine is one of the " DOXFORD " style not at all odd. Have you still got the injector? I think the fuel pump will be a flange mount and if you scavenge around a small unit from a " VILLIERS " or little " LISTER " could be adapted. Food for thought. Maybe look at a little " STUART-TURNER " pump. The pictures on Christian's site, the "einweller is the "doxford " and the "zweiller " is the "fairbanks-Morse style. Another is the TS3 or " Tilling-Stevens " o.p with 3 cylinders, 6 pistons, connecting links to a single crankshaft.Hope this does'nt confuse you. |
raymond
| Posted on Thursday, June 17, 2004 - 07:54 pm: |
PETER, those engines were also known as the "side-rod " type. They were very popular in both truck and marine installations although I had no idea they were made as small as yours. |
Peter Dixon
| Posted on Tuesday, June 22, 2004 - 07:30 am: |
Thanks Christian and Raymond. had no luck reading German! Christian may be interested in my lanz 15ps stationary engine, no6362 on tony burnell's lanz site.I also own n model Bulldog no 645647, 35 hp.Sorry, this has nothing to with marine tho.I have all of Junkers mk 65 except pump. injector in pieces, so possibly incomplete. Yes pump from single cylinder diesel could be adapted using existing cam but I think a linkage to rack would have to be sorted out.not much of a problem if one still had enthusiasm of 20 yrs ago!I could post some pics of dismantled engine if you are interested. Regards Peter |
raymond
| Posted on Monday, June 28, 2004 - 05:54 am: |
PETER D. If you were a little closer I would take that engine off your hands, but as I am in Queensland, Australia and you are where?? we are getting no=where. If you get the nozzle # you can get an approx. opening pressure from other similar injectors, the actual pump delivery capacity is not all that critical, just to get an engine running. It's surprising that when you take a runner to a machinery day and people see and hear it they front up and tell all sorts of stories. I know where there's one, I've got one, all that sort of thing. Any way, keep us posted. Like to hear more/ |
peter dixon
| Posted on Friday, July 09, 2004 - 08:11 am: |
raymond, engine not for sale! have a few others that i should get going first tho. also my f/glass boat with 4hp regal engine. am in tas. 0364423547 |
rholcomb Visitor
| Posted on Friday, July 09, 2004 - 07:48 pm: |
peter i have a 7hp regal can you post some pictures of yours thanks bob |
peter dixon Visitor
| Posted on Thursday, July 22, 2004 - 06:07 am: |
rholcomb,sorry, digital camera broken. will borrow one and take pic after i put engine back in boat in month or two .regards peter |
Jon T
| Posted on Wednesday, July 28, 2004 - 05:00 am: |
My father drove lorries with TS3 engines in for a few years in the 50's and 60's.. He still owns one but it's a bit grown in, it was actually driven to the position it's in now and both he and I are anxious to get it running again, unfortunately the cab has completely disintegrated but the engine should be in better shape. I will have this as my project when it's out of the mammoth hedge it now occupies. Unfortunately my uncle sold all the TS3 parts and spare lorries he had to a collector in the 80's, they would now be worth around �50,000 I imagine. So I'm just stuck with this rotted one with no spares, although it's the very one he drove for 4 years delivering cattle. It would be meaningful to get it running again and I intend to do all I can. Please email me if you know of any spares suppliers who may have anything for the TS3. Thanks, Jon. |
peter_bell
Member Username: peter_bell
Post Number: 5 Registered: 09-2004
| Posted on Monday, January 10, 2005 - 03:21 am: |
Peter, Did you ever manage to sort your fuel pumps for your Junkers HK65. I have two HK65 stationary engines with pumps and it would be possible to take photos if that would help? Peter |
peter_dixon
New member Username: peter_dixon
Post Number: 1 Registered: 12-2004
| Posted on Monday, January 10, 2005 - 05:30 am: |
thanks peter but i have done nothing with it so far. but have my motor boat back on water. will post pics of regal engine for rholcomb soon. there is a stationary mk 65 a couple of blocks from here. may be for sale, deceased estate,it may turn up on ebay. saw an mk 65 in stationary engine mag years ago with lister cs type pump (i think) mounted on top of governor housing, as raymond suggested ,it may be the way to go.regards peter |
Christian Schupp
| Posted on Thursday, October 27, 2005 - 01:11 pm: |
Sorry that I did not answer again. Do nit try to adjust the opening pressure like raymon told you. Junkers Engines have open injector nozzles. They dont have springs or adjustment screws inside. It just has to be clean to work properly. |
rayman
Member Username: rayman
Post Number: 6 Registered: 10-2005
| Posted on Thursday, November 17, 2005 - 07:12 pm: |
Christian, I have spent many years in fuel injection and the only "open" injectors I have seen have been fitted to "air blast injection systems" can you post a pic or give a clear description please of a junkers type regards rayman |
neil_t
New member Username: neil_t
Post Number: 1 Registered: 01-2023
| Posted on Monday, January 16, 2023 - 08:54 am: |
Trying to get in touch with Peter bell with a couple of questions about my junkers engine, if anyone has his email. Thanks neil. |
