Eisemann 71-S Repair
Old Marine Engine » Timers, Magnetos, Ignition » Eisemann 71-S Repair « Previous Next »
John Graham
Username: bigjohng2
Posted on Thursday, August 04, 2022 - 01:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I was introduced to your site by Jim Barrett (Angus) of Camas, WA at
the Great Oregon Steam Up at Brooks, OR this past weekend. Jim is the
mag expert at the show.
What I have is a Lauson LF 822-2 2 1/2 hp water cooled motor that has
an issue... NO spark. Jim tested the mag which is an Eisemann model
71-S and found it to be bad. So what I am looking for is a good
replacement coil. An Eisemann p/n 24004 includes the laminated core .
The hole in the coil measures 5/8 inch x 5/8 inch. What I am looking for
(I think) is a modern coil that would fit my application.Do you have any
suggestions that would work?
miro forest
Post Number: 1189
Posted on Saturday, August 13, 2022 - 11:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
A Tecumseh lawn mower coil might work - looks to be about the right size.
