Gasoline Union for Schebler carburetor
Old Marine Engine » One and Two Cylinder Gas Inboards » Gasoline Union for Schebler carburetor « Previous Next »
Norm McIntosh
Posted on Sunday, February 20, 2005 - 03:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi: I am looking to purchase two gasoline unions for my 1" schebler carburetors It is a 90 degree bronze/brass piece with internal threaded ends. It is used to attach the gasoline line to the carb.
If anyone knows where I could purchase these for my St. Lawrence engine, it would be greatly appreciated. I would like the carbs to be original.
Footnote: Because of this discussion board I was able to get new rings for my St. Lawrence from Otto Engine works.
Dave Reed from Otto was super and I received them in the mail in no time flat.
Thanks...... Norm
paulgray
Username: paulgray
Post Number: 120
Posted on Sunday, February 20, 2005 - 08:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I thing George Coates is making these- Pretty nice stuff, very hard to tell from original. His are threaded 1/8 NPTF on the inlet to hook a compression fitting to. Those old style with the rope packing are a prone to be leaky.
george_iv
Username: george_iv
Post Number: 126
Posted on Monday, February 21, 2005 - 02:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yes, they are available. If these look like something you could use let me know. They are NOT original equipment. They are exactly the same as original with the appropriate knurl for either the Dribler or the Monarch. It does make a difference!!! The covers are cut for the gasket, and the inlets work well. I will have a handfull of them at the Calvert show. See you all there.
George CoatesCarb Parts
Norm McIntosh
Posted on Saturday, February 26, 2005 - 03:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank-you for the pictures George. I have e-mailed you with my request..... Norm
