Frisbie 5HP Inboard Motor
Old Marine Engine » One and Two Cylinder Gas Inboards » Frisbie 5HP Inboard Motor « Previous Next »
mtbjeff
Username: mtbjeff
Posted on Tuesday, March 28, 2023 - 03:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm looking for any information on a Frisbie Marine Motor, single cylinder 5 hp A motor with a 4 3/4 inch Bore and a 5 inch Stroke Serial No A1688. The Motor was built sometime between 1909-1920 I believe. It has an Air Friction Carburetor that looks original. Here are some pictures of my Motor
Jeff
mtbjeff
Username: mtbjeff
Posted on Tuesday, March 28, 2023 - 03:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is a maybe a better picture of the engine
mtbjeff
Username: mtbjeff
Posted on Tuesday, March 28, 2023 - 04:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here are some pictures of the Air Friction Carburetor and an unknown to me ignition. Any help in identifying it would be greatly appreciated. I did read that Frisbie used Atwater Kent Ignition on some motors
Jeff
Post Number: 1224
Posted on Saturday, April 01, 2023 - 11:32 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have a look at for the info on the Atwater kent ignition system.
https://www.oldmarineengine.com/discus/messages/3457/2848.html
Yours might also be a more conventional buzz coil type with a timer.
If you take off the cover plate, you'll either see the AK mechanism, or a rotating contact that will contact the insulated screw contact.
The AK Unisparker usually has a different top connection for the sparkplug than yours.
In either case you will need a coil of some sort.
The AK system has some mystery to it, but by all accounts works well. It provides one spark per rev, whereas the timer/buzzcoil type will make multiple sparks per rev.
