Blaxland/lucas sr1 Magnito?
Old Marine Engine » Blaxland » Blaxland/lucas sr1 Magnito? « Previous Next »
Allen Flux
Username: busted_knuckles
Posted on Tuesday, November 08, 2022 - 12:21 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I aquired a Lucas SR1 magneto which was dismantled to replace rusted bearings. Is there such a thing as workshop manual for the Blaxland/lucas sr1 Magnito?
Allen Flux
Posted on Tuesday, November 08, 2022 - 12:33 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Reworded. Wanted manual for Blaxland/Lucas sr1 magnito for 5/7 twin. I need to time the drive gear to put the rotor button in the correct location.
Allen Flux
Posted on Sunday, November 13, 2022 - 10:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Rather than leave my question without an answer I contributed my solution. Using the principal simlar to timing a motorcycle. No1 Piston set to 7/16" before tdc, points beginning to open; with rotor button removed,set the drive gear with a light tap on armiture. Make sure the rotor button is positoned to front cylinder. Advance and retard would be good.
