graymarine 4 model 70
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » graymarine 4 model 70 « Previous Next »
jeff c
Posted on Thursday, November 22, 2001 - 01:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I got my electrical problem solved, much thanks! however, I cannot seem to get any fuel from the carb. The engine will start by pouring gas directly into the cylinders. I did clean the carb which looked good. I am bypassing the fuel pump and sending gas directly to the carb via a pump bulb, and my starter does seem alittle sluggish are these contributing problems? also, what is the configuration of the carb/throttle for starting?
p.s. the crankcase oil is also the trans. oil?!!
olarry
Posted on Thursday, November 22, 2001 - 05:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Your manifolds could be blocked or have a hole.Can you choke the carb and hear it suck in gas.Can you spray starting fluid into the intake and make it fire?Throttle should be 1/2 to full open and choke closed to start.Open choke 1/2 when it hits.Open more if it smokes black.
Posted on Wednesday, January 02, 2002 - 12:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yup, the crankcase oil and the transmission oils are usually shared in engines of that era. I believe that it made them easier to manufacture (avoided duplicate oil seals and alignments)
Carlton Day
Posted on Tuesday, March 22, 2005 - 04:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have this same engine in my Marinette. How can I find the year model of this engine? The engine # is K2131. Also how about a parts supplier and manual? Thanks for your help.
Carlton
poker casino775
Posted on Monday, March 06, 2006 - 06:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 640
Orin 'Dennis' Mullen
Username: dennismullen
Posted on Tuesday, August 31, 2021 - 05:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Year/Number list: http://www.finewoodboats.com/Gray.htm
