Need Parts For Gray Marine 327 Fireba...
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Need Parts For Gray Marine 327 Fireball V8!!! « Previous Next »
Chris Bradford
Username: ryancbrad
Posted on Sunday, May 29, 2016 - 08:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello All!
I have an old boat that I am restoring and it has an old Gray Marine 327 Fireball 225 in her (V8C225, W-6100). It definitely needs two exhaust manifolds as the current ones have crapped out. Anyone here have any that they would like to sell? Or do any of you have an engine that they would like to sell?
Ted Dysart
Username: 61sabre
Posted on Friday, July 22, 2016 - 04:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What year is that engine? I have two manifolds from a 1959 Graymarine Fireball 188. The engine is a 327 but the manifolds are the 3-bolt style, and I really need one 4-bolt manifold, from 1960 forward. Would you be interested in purchasing mine? They are in great shape, and include the elbows. I will reduce the price if you send me your junk ones.
Rick Irvine
Username: rick42wood
Posted on Saturday, August 10, 2019 - 05:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Grey Marine engine that is probably what you are looking for. It is marked 225 HP. If you are still looking I could send some pictures
David Troxell
Username: amcenthusiast
Posted on Wednesday, September 25, 2019 - 09:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You might find my website of interest while planning to rebuild the engine:
http://www.amcramblermarlin.1colony.com
Ted Dysart
Username: 61sabre
Post Number: 16
Posted on Saturday, May 22, 2021 - 07:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Rick42wood, I just saw your post from 2019. I do need one manifold, but it has to have the 4-bolt end cap. Send pics to [email protected]. Or text to 972-816-1348. Thx.
Chris Turley
Username: resorter60
Posted on Thursday, September 29, 2022 - 11:09 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looking for a fuel pump, a distributor cap and rotor for a 1960 gray marine amc 327. It�s in an 16ft. 1960 Century Resorter. Any help will be greatly appreciated.
Simon Bartrop
Username: simonbartropgooglemailcom
Posted on Wednesday, November 23, 2022 - 04:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looking for exhaust manifolds (2 pass) to fit a GM small block 327 from 1962.
Also looking for advice on restoration of a 327 GM small block Engine from 1962. originally a crusader marine engine build.
