Schebler Carburetor (or something sim...
Old Marine Engine » Carburetors, Mixers, Vaporizors » Schebler Carburetor (or something similar)? « Previous Next »
Marko Vahtokari
Username: marko
Posted on Tuesday, September 14, 2021 - 10:18 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi.
I found and bought this old carb just because it looked very interesting.
Did not know a thing about it but looking through net I found some similar items.
I don�t really have anything where I can use it so I�m willing to sell it but first I would like to know more about it.
miro forest
Post Number: 1157
Posted on Wednesday, September 15, 2021 - 10:09 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It has some of the same characteristics as a Schebler Model D - one of the most common carbs used on marine engines. But it does not have the usual air horn. The picture shows the carb sitting upside down.
It might be a Schebler copy - there were more than a few companies that did such copying. Some worked better than others as caburetors.
If there are no markings or name , then it most likely is a copy.
