Brass propeller shaft
Old Marine Engine » Miscellaneous » Brass propeller shaft « Previous Next »
david_woodworth
Username: david_woodworth
Post Number: 30
Posted on Thursday, August 26, 2021 - 01:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I need a 1 inch shaft 43 inches long, does anyone have one they will sell?
Post Number: 1152
Posted on Thursday, August 26, 2021 - 09:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
David, I think what you are looking for is a bronze shaft, not a brass shaft. A brass shaft would probably last , maybe 2 or 3 minutes before twisting off.
As an suggestion, you might want to consider a stainless steel shaft - they're just as good as bronze , do not corrode and are certainly less costly than a bronze shaft.
miro.
