Dick yant
| Posted on Sunday, April 04, 2010 - 08:09 pm: |
i have a 1975 MD6A that isn't getting any cooling water. I have traced it back to the transmission cooling jacket being blocked. i opened up the three openings on the transmission and tried forcing water in with a garden hose. and the back flushing it with 90 pounds of air pressure. The engine has sat unused in salt water for two years, the previous owner said he noticed the cooling water output slowing down. is there some way to flush out the transmission without removing it from the boat. thanks for the help, dick |
matt_morehouse
Advanced Member Username: matt_morehouse
Post Number: 43 Registered: 12-2009
| Posted on Sunday, April 04, 2010 - 11:16 pm: |
You say, "...unused in salt water" does that mean it has been under salt water? |
mashilo
New member Username: mashilo
Post Number: 1 Registered: 11-2020
| Posted on Tuesday, November 17, 2020 - 04:24 pm: |
Hi. Just came across your post because I have an MD6B that had also had reduced water flow out of the exhaust and over the weekend stopped spitting water altogether. Luckily, I was able to sail almost all the way back and didn't overheat the motor. Did you fix your problem? If so, what did you do? Thanks! |
