Gray Marine Model 175
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray Marine Model 175 « Previous Next »
Neal Whitehead
Posted on Monday, October 18, 2004 - 11:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1957 18ft. Century Resorter with a model 175 Gray Marine six cylinder motor. It is a dual carb.,copper chrome,individual porting,ser# G14178. I would like to know the cubic inch and hp of this engine and any other info about motor, or a link to web site for info. Thanks
Moderator
Username: andrew
Post Number: 943
Posted on Tuesday, October 19, 2004 - 06:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Information from the Handbook as follows:
  • Model 175
  • 6 cylinder
  • 4 x 4-11/16
  • 363 cid
  • 175 HP @ 3400 rpm
  • Weight: 1050 lbs w direct drive
  • 1250 lbs w reduction drive
Neal Whitehead
Posted on Tuesday, October 19, 2004 - 08:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank you very much for the information. This boat is a direct drive unit,any guess what kind of speed this boat will do? The motor is a lot bigger than other boats of this size that I have seen. Do you or any one think this is the correct motor for this boat?
Edward Schmitt
Username: cowboy
Posted on Monday, July 18, 2022 - 10:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looking for information on a Gray marine model 175, it is in a 58 Coronado, hard to find parts for? were they dependable Motors? The motor is in the boat I am thinking of purchasing, Thanks!
