R type water pump valve cap & valve d... |
Hugo de Rrick
New member Username: hugo_de_rrick
Post Number: 1 Registered: 10-2014
| Posted on Thursday, December 18, 2014 - 01:54 pm: |
Hullo - As I've just been making replacement R type valve caps & valves, I thought I'd share the drawings for others to use... However, they're > 200K, so if you'd like a copy of either / both, drop me a line. Ciao, H. |
Andrew Menkart
Board Administrator Username: admin
Post Number: 21 Registered: 07-2001
| Posted on Friday, December 19, 2014 - 09:17 am: |
Hugo, YOu could reduce the image size in any photo editor and then post it here. If you don't have an editor we have a resize tool here: http://www.oldmarineengine.com/resize/resize.html |
Hugo de Rrick
Post Number: 2 Registered: 10-2014
| Posted on Sunday, January 04, 2015 - 11:36 am: |
Hi Andrew - Thanks for the link - alas, the drawings are PDF files which, even when zipped, are still > 200K... Regards, H. |
Jarrod Barker
New member Username: jarrodb291
Post Number: 1 Registered: 01-2020
| Posted on Sunday, January 12, 2020 - 04:10 am: |
Hi Hugo, Do you still have the drawings available? |
Hugo DeRrick
New member Username: hughgoderrick
Post Number: 3 Registered: 04-2020
| Posted on Friday, April 17, 2020 - 09:41 am: |
Hi Jarrod - Drawings pm'd over to you. Cin cin, Hugo. |
