Newage "B" Type Mechanical Gearbox: S...
Old Marine Engine » Gears, Transmissions, and Propellers » Newage "B" Type Mechanical Gearbox: Seeking parts « Previous Next »
Craig Rose
Username: craigrose
Posted on Friday, April 25, 2014 - 11:26 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi
I have a gearbox which carries the following information on an attached label.
Name plate
Newage BMC
Marine Engine
Newage Group Commander
Eng No: 3519 305
Newage (Manchester) LTD
Gorton Manchester England
I believe that this is a Newage "B" Type Mechanical Gearbox. Can any one help me locate a parts supplier? I am in Australia.
Many Thanks Craig
Chris G Gilly
Posted on Sunday, June 28, 2015 - 11:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Craig,
Have you had any luck. I have the same gearbox and need a workshop manual
cheers
Chris
Wolfgang roman tiwini Hetet schmidt
Username: wakawolf
Posted on Friday, May 15, 2020 - 03:00 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hey fellas got a newage gearbox for a 2.2 bmc commander and wondering how any of you got along with it.
Mine is running a I can drop it in and out of gear with a wrench, but I've taken the old hydraulic system to change the transmission and installing cables to shift gears.
Any advice?
