Where has everyone gone to??
Old Marine Engine » Miscellaneous » Where has everyone gone to?? « Previous Next »
bruce
Username: bruce
Post Number: 673
Posted on Saturday, April 27, 2019 - 09:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Very few posting OME topics these days. I'm having withdrawal from lack of contributors. I check this site every day multiple times....
dick_briggs
Username: dick_briggs
Post Number: 31
Posted on Sunday, April 28, 2019 - 06:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bruce, I understand and feel the same way, but since I seldom post anything, I can't really complain. So here is my current project - a Palmer Q2. Most parts are there, but making lots of nuts, bolts, and shims; the intake and exhaust need a bit of welding and the timer is an odd one that needs a bit of modification.
Post Number: 2510
Posted on Monday, April 29, 2019 - 04:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have been working on some real big steam enignes at a local museum. The biggest project has been replacing all the steam lines in the building. 2 inch screwed together black iron pipe.
boiler made in 1966. The horizontal steam engine is an Erie City about 10 by 12 bore and stroke. The round thing that is running is a GE steam turbine direct connected to a DC generator. 125 volt I think. The vertical engine is a Troy Egberg. Not sure on the size.
Post Number: 2511
Posted on Monday, April 29, 2019 - 04:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
We were the recipients of another large mill engine. A Rollins made in Nashua, NH.
It sat undisturbed from the end of WW2 until December 2018 when we moved it from the Gurney Tack Co in Whitman, MA to the New England Wireless & Steam Museum in East Greenwich, RI.
Link to more info on this engine.
https://newsm.org/steam-e/rollins-engine-moved/
Also while you are there take at the rest to the museum web page.
https://newsm.org/
Enjoy
Post Number: 2512
Posted on Monday, April 29, 2019 - 04:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is the star of our Steam Engine Collection
https://newsm.org/steam/corliss-steam-engine-1892/
Post Number: 2513
Posted on Monday, April 29, 2019 - 04:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Our Fitchburg engine. The donation of this engine was arranged by Dick Day. It ran a mill in Peterboro,NH. Dick spent a large part if his early years there.
https://newsm.org/steam/fitchburg-steam-engine-1905/
Post Number: 2514
Posted on Monday, April 29, 2019 - 04:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is a pic of one of 4 Rollins flywheel hub bolts. There are also 10 rim bolts 5 in each side. The flywheel as you can see in the pic in the link above is in 2 halves. Each half weighs about 9300 pounds.
Post Number: 2515
Posted on Monday, April 29, 2019 - 04:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is the Rollins the morning we started the moving process. It had been under cover till the building was removed about a month before we moved it. The flywheel is about 15 ft in dia.
Post Number: 1418
Posted on Tuesday, April 30, 2019 - 09:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie, wish I was closer or retired, I'd be helping, looks like my kind of fun. Nice work.
Post Number: 2516
Posted on Tuesday, April 30, 2019 - 09:54 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
JB
Thanks it is hard work but fun and very rewarding.
Post Number: 2517
Posted on Tuesday, April 30, 2019 - 09:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Around 3000 pounds of crankshaft. Notice the bottom half of the flywheel which is resting on timbers across the flywheel pit. It was next to remove.
