Gray Marine Phantom four 45 PISTONS
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray Marine Phantom four 45 PISTONS « Previous Next »
Antoine Lebel
Username: ascagne
Posted on Monday, March 11, 2019 - 06:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello,
need help from the experts.
I am in the process of restoring my Gray Marine engine.
The pistons need to be changed. They are a little loose in the cylinders. I see that on the head of the pistons the specs is engraved "090". Somewhere I read that Phantom Four 45 had "0,91" specs. Could the pistons have been changed with the wrong kind? Does anyone know, if I need to put slightly larger pistons, what increment is above "090"? "100"?
Also I am after the colour code for the green-blue-gray these engines were painted with.
Thank you for any help you could provide.
Jim Staib
Username: drrot
Post Number: 261
Posted on Tuesday, March 12, 2019 - 08:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Measure them. Quite possibly they are .060" oversize right now.
Antoine Lebel
Username: ascagne
Posted on Tuesday, March 12, 2019 - 04:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Quite right about being .060! I was looking at the digits from the wrong side!!
I know now where to get these pistons and will put sleeves in to make them tight again.
Anyone knows the colour code for the Gray Marine engines?
Bruce Hall
Username: bruce
Post Number: 671
Posted on Tuesday, March 12, 2019 - 08:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I was always told the Gray Marine paint is same as Detroit Diesel engine paint color
Antoine Lebel
Username: ascagne
Posted on Tuesday, March 19, 2019 - 01:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Bruce. I think you are right about the Detroit Diesel engine colour. A sort of Alpine green. What I need is to find the colour code, so I can replicate the colour here in Europe as it is impossible to import paint from the US.
Antoine Lebel
Username: ascagne
Posted on Tuesday, March 19, 2019 - 01:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Anyone knows how to get a hold of Dave Van Ness at Van Ness Engineering? I have sent him an email, left messages on his answering machine, but to no avail. Perhaps a cell phone?
Jordan Heath
Username: fireballing
Post Number: 20
Posted on Friday, August 23, 2019 - 03:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Antoine, did you find the paint color yet? "Dupli-Color" DE1618 Detroit Diesel Alpine Green, sold in the US in a rattle can, is nearly an exact match for Graymarine.
