Volvo MSB gearbox oil
Old Marine Engine » Diesel Inboards » Volvo MSB gearbox oil « Previous Next »
cd33
Username: cd33
Posted on Thursday, March 21, 2013 - 11:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi,
I have a MD11C with an MSB gear box that has the friction lining on the cone. The manual calls for a 20 weight oil above 50 degrees. Maybe I should not try to out think the engineers that designed it, but 20 weight seems very light to me especially for the tropics where I am located. Does anyone know if Volvo ever changed the oil specification to a heavier oil. Why would they spec such a thin oil. Input please.
florida_carole
Username: florida_carole
Posted on Thursday, May 16, 2019 - 05:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
A little late on this post but I have the same issue with my volvo MD11c (2 cyl) diesel. Living in the tropics I don't think 20 weight oil is thick enough for the high temps here. I switched to Rotella-T 15W 40 diesel oil thinking the 15W would be fine for starting and the 40 would be better protection when running. Would appreciate any advice anyone has on this as I feel unsure and don't want to screw up the engine. Also note reverse gear for this engine is supposed to use same oil as engine.
