Right hand rotation YT1
Old Marine Engine » Palmer Engine Co » Right hand rotation YT1 « Previous Next »
Vic Rosser
Username: jwales
Posted on Thursday, February 14, 2019 - 05:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Gentlemen, I may have inquired here before about my trailer hand rotation YT1 but I can�t find a thread related to this. Anyway, located this Palmer in Washington County Maine sitting in a field seized. With minimal effort it freed up and I had her running in a day or so if getting her home. It even had a functional reverse gear. It took some coaxing to get the gear to work but I was patient. It�s the only one I�ve ever seen with the carb on the right side and the carb has what I think is an anti backfire valve. It�s the right hand rotation that is puzzling about this engine. When I figure out how, I�ll post a short video of it running. It has a large data plate with Rapp-Hutchins Co on the cyl.
Post Number: 4137
Posted on Friday, February 15, 2019 - 06:34 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Rapp-Huchins company without the T you will find
info online. Est about 1900 incorporated 1908 was
a machine-tool-engine distributor, sold many different named companies marine engines.
1928 advertised Rapp made conversion parts for Ford engines, advertised M&D Machine Co. converted ford engines.
