1953 Gray Marine 620 4cyl water pump |
Frederick Vare
New member Username: 52atom
Post Number: 1 Registered: 06-2024
| Posted on Wednesday, June 05, 2024 - 04:55 pm: |
I am looking convert my grease cup water pump to the rubber impeller type. Does anyone know of how I can source one? Any leads appreciated |
miro forest
Senior Member Username: miro
Post Number: 1254 Registered: 11-2001
| Posted on Tuesday, June 18, 2024 - 06:19 pm: |
I wouldn't do that . The rubber impeller pumps can lose the prime and the rubber impeller will elf destruct in less than a minute. The trick with the gear type water pumps is to make sure that the ends of the gears and the housing is a very good and flat match. The gear teeth can be worn down to sharp points but as long as the end parts are a close fit, the pump will work 100% |
