65 HP (?) Gray Marine water in the oi...
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » 65 HP (?) Gray Marine water in the oil « Previous Next »
kaptinken
Username: kaptinken
Posted on Wednesday, December 01, 2004 - 04:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1947 Lyman Islander with a 4 cylinder 65(?) HP Gray Marine gas engine, Shortly after buyng the boat, I found water in the oil. I have pressure tested the oil cooler, and pulled the intake/exhaust manifold (due to a small crack in the exhaust side)for pressure testing and braising.
After changing the oil and running the engine, the oil appears within a few minutes at idle. It runs very well and purs like a kitten.
Does anyone have any advice or a source for parts and gaskets?
Moderator
Username: andrew
Post Number: 981
Posted on Wednesday, December 01, 2004 - 10:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
quote:
Try Gary at Bristol Marine in California. I'm at work now and only have his phone number on my cell phone, but not his city; it's somewhere in Southern California. His number is 714-846-2039. He's helped me with my Gray Marine
412 in an old 40-foot Kettenberg.
Paul
