1952 Chrysler M48 Water Pump?
Old Marine Engine » Multi Cylinder Gas Inboards » 1952 Chrysler M48 Water Pump? « Previous Next »
Dave P
Posted on Wednesday, July 26, 2006 - 04:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a straight eight flathead 1952 M48 Chrysler w/ a leaky water pump. I have already tightened the packing nut on the water pump. This did not solve the problem Does anyone know which type of packing I can use to replace the original?
shawnstam
Username: shawnstam
Post Number: 17
Posted on Tuesday, January 09, 2007 - 12:34 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
maybe a wax type that is used in the shaft log. it comes any many sizes. you could also consider have it machined so you could put a O ring in its place
phillip_carlton
Username: phillip_carlton
Posted on Monday, January 28, 2008 - 10:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dave,
Just wondering how you solved your water pump problem? I have a 1953 Chrysler Roual M48 in need of an intake manifold and exaust elbow casting # 4028H. I have a spair water pump that needs rebuilding. Anyone have any suggestions?
[email protected]
