Can some identified this timer...
Old Marine Engine » Timers, Magnetos, Ignition » Can some identified this timer... « Previous Next »
Joe
Posted on Monday, January 21, 2002 - 10:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It is an Atwater Kent timer for two cylinders complete with bracket and brass drive gear. I bought the timer for one of my Easthope engines. The bracket is for some other engine but what?
Anyone know...? I can email a larger format picture if it would help anyone.
Thanks, Joe
timer
Richard Day
Posted on Monday, January 21, 2002 - 09:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Better make sure which direction it must turn. I cannot tell for sure but it looks like it has two towers at 90 degrees which means it was intended for a four cycle, two cylinder engine It requires a special coil and don't try to adjust or file the points. They move so fast the human eye cannot see them move. It will not work with a typical automotive coil. You can wreck the points if you try. It will not work with a buzz coil either. You have been warned. They are rare and people look for them.
Joe Holmes
Posted on Wednesday, January 23, 2002 - 02:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for the good advice Dick. Indeed the timer is for a two cylinder four cycle engine and the timer turns clockwise. The question is: what engine is it from, can you tell by the bracket? If you don't recognize the bracket then its not from a Palmer I should think.
Richard Day
Posted on Wednesday, January 23, 2002 - 06:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Joe its not from any Palmer I have ever seen photos of. It doesn't ring a bell in any engine I know of. Too bad it doesn't turn counterclock wise and then you could use The timer part on any of the NL and NR or their off-spring like the ZR. Have you gotten my draft write up on the those engines yet. I think I sent it out last Friday or Sat. I also sent some out on Tuesday so you may not have received it yet. Hope you can add some thoughts to it. Regards Dick
Joe
Posted on Monday, January 28, 2002 - 02:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Dick. Got the draft and have an addition for you. Also, I received an e-mail from a gent in Australia who also has a Palmer "R". His is closed to running. I'll pass it on with my revisions.......Joe
