Palmer 27HP 4 cylinder
Old Marine Engine » Multi Cylinder Gas Inboards » Palmer 27HP 4 cylinder « Previous Next »
saltydingo
Username: saltydingo
Posted on Sunday, February 26, 2006 - 11:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I've got an engine in a 1974 Coronado 28 that I need a little info about. I'm told its a Palmer 27hp engine, but I could not find that info on the web about that model.
Its an in-line 4 cyl. My questions are:
Which is Cylinder #1?
Is the firing order 1-3-4-2?
Any other info you have about the engine would be appreciated.
eddie
Username: eddie
Post Number: 107
Posted on Monday, February 27, 2006 - 11:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
A Palmer P-60. You have the correct firing order ( 1-3-4-2 ) #1 is at the forward end. You have one of the the engines produced shortly before they were discontinued.
I recommend that you put your questions under Palmer Engine Co.. Put P-60 somewhere in the title. Ask questions about more specific problems. You'll find lots of good help on this board.
richardday
Post Number: 299
Posted on Monday, February 27, 2006 - 06:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Eddie I fell flat on my face with out thinking I told a man the number one cylinder was on the forward end. Unfortunately he had a V drive in his boat and we had a lot of trouble until I realized what his problem was. I now tell people this the number one cylinder is next to the flywheel. Actualy in the the the tractor that cylinder is the number four cylinder but don't tell people that as that will really mess us up. Regards, Dick
eddie
Username: eddie
Post Number: 108
Posted on Monday, February 27, 2006 - 09:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
OK, Richard. You never can be too sure someone will get your directions right. I'll use a double reference in the future. Cheers, Eddie
