Bedford exhaust manifold oil leak
Old Marine Engine » Diesel Inboards » Bedford exhaust manifold oil leak « Previous Next »
bedford_gm
Username: bedford_gm
Posted on Sunday, July 12, 2015 - 12:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ive recently installed 2 GM Bedford 466 cu inch series 70 engines in my boat. they were supposively rebuilt for a 70 ft sailing boat but proved to be not power full enough, they start and run good, but use quite a bit of oil, (a quart every 6 hrs but also they leak oil out the two end exhaust manifolds on both engines?.
ive only run the engines for about 20+ hrs , appreciate any thoughts you guys may have
bedford_gm
Posted on Thursday, July 23, 2015 - 09:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
