Palmer M60/P60 seals
Old Marine Engine » Palmer Engine Co » Palmer M60/P60 seals « Previous Next »
Curt Larsen
Username: curtlarsen
Posted on Wednesday, June 21, 2006 - 10:55 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm rebuilding my M60 and want to replace the font and real seals. The numbers of the present ones are: CR 18785 USA, and CR 29887 USA. Who would be the best supplier for these in the MD/VA/DC area?
Curt
Lawrence T Wolfe
Username: larry_from_maryland
Post Number: 175
Posted on Wednesday, June 21, 2006 - 11:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You could probably get them from specialties they should be in a metro area phonebook under bearings.You could try a good napa place too.
Post Number: 343
Posted on Wednesday, June 21, 2006 - 06:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Try Valu Bilt Tractor Parts. 1-888-828-3276 or www.valu-bilt.com You are looking for seals for the IHC Cub Lo-Boy C-60 engine. Don't talk Palmer they won't know what you are talking about. Palmer Marinized the IHC Cub Lo-Boy engine. They refer to it as the C-60 engine. If not Valu Bilt go to any IHC tractor dealer. Not truck dealer and they can get the engine seals you need. The Reverse gear seal go to any bearing and seal dealer and show him the seal you need and you should have no problem. Just Remember the Cub Lo-Boy is not the CUB CADETand most IHC truck dealers are no longer IHC tractor dealers.
Dean252
Posted on Friday, August 18, 2006 - 04:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
www.yesterdaystractors.com also has parts for C-60, including full rebuild kit (seals, gaskets, pistons, rods, rings and bearings).
