Owens flagship engine i.d.
Old Marine Engine » Multi Cylinder Gas Inboards » Owens flagship engine i.d. « Previous Next »
Rossdaboss
Posted on Tuesday, March 24, 2009 - 12:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a mostly complete engine that I'm trying to sell. Block number is 3782870. It has a Velvet Drive AS1-71C transmission. Does anyone know if this is a 327 or 283?
Engineguy
Posted on Monday, May 18, 2009 - 04:32 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Your engine is a 1962-65 GM 327
bartropr
Username: bartropr
Post Number: 91
Posted on Monday, December 17, 2018 - 12:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My nephew is restoring a Boesch 5.6M which was made in Switzerland, It is powered by a 1962 Crusader Marine (Chevrolet 327Turbofire?) engine. Serial Number 3683
Both the water cooled exhaust manifolds need replacing. The righthand one has "Model RH230" cast on it. The manifolds for these are probably ok from 1961-1965 engines.
Does anyone know where you can get replacements? does anyone make new ones, or we going to have to look for ones off an old engine?
drrot
Username: drrot
Post Number: 254
Posted on Tuesday, December 18, 2018 - 09:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'd find new ones. Just make sure to hook up the water flow on the new ones like the old ones. Barr marine makes several. Aluminum ones are also out there.
