any information on Ford 254 diesel in...
Old Marine Engine » Diesel Inboards » any information on Ford 254 diesel inboard engines urgently needed. « Previous Next »
Reg Chenery
Posted on Monday, February 09, 2004 - 11:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
At present the motor has been honed, new rings, head job, bearings, crankshaft, rockers faced, new injector pump ........... in effect the only old parts are pistons (on size).
Could someone let me know the running oil pressure, running temp and run-in time before being put under power.
Any help appreciated.
Reg
Reg Chenery
Posted on Monday, February 09, 2004 - 11:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just thought I should add that the Ford inboard motor series is 4D254.
Thanks for any help.
Reg
Posted on Thursday, February 12, 2004 - 12:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Reg,
According to the manual:
NORMAL OIL PRESSURE: 30 psi at 1600 rpm, 35 psi at 2000 rpm.
OIL TEMP (range): 165 - 220 degrees
COOLING SYSTEM
OPERATING TEMP: 175 - 190 degree f
OPTIMUM TEMP: 195 degrees f
Regards,
Andrew
susan jones
Posted on Friday, February 13, 2004 - 11:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Andrew,
Lucky Reg has gone fishing for a few days. When he gets back I know he will be pleased with the necessary information you have passed on.
Sonja
