Mechanical oil pressure gauge
Old Marine Engine » Palmer Engine Co » Mechanical oil pressure gauge « Previous Next »
kevin stone
Username: kdstone
Post Number: 81
Posted on Tuesday, January 22, 2019 - 05:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi guys, does anyone know what the correct type of tubing for a mechanical oil pressure gauge should be? Can I use rubber fuel line? What's the maximum length for the tubing? I think 5-6 feet would get the gauge where I want it.
Scott Noseworthy
Username: scott_n
Post Number: 310
Posted on Wednesday, January 23, 2019 - 08:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My 1955 Chris craft came with copper tub
Jim Thomson
Username: brownboat
Post Number: 22
Posted on Wednesday, January 23, 2019 - 07:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Why use a rubber hose to transfer a pressure. Copper tubing should work real well.
Ned Lloyd
Username: ned_l
Post Number: 187
Posted on Monday, February 04, 2019 - 12:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
yep, ..... copper tubing and flare fittings is what was standard (and is what is on my engines).
