Gray 109 RPM "gadget" on Head
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray 109 RPM "gadget" on Head « Previous Next »
Eric Peggs
Username: epeggs
Post Number: 40
Posted on Tuesday, September 18, 2018 - 11:54 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
When at higher RPM's oil will leak out of the RPM "gadget" connected to the cam shaft that is located on the head of my Gray 109. Is there supposed to be a gasket there or do i have bigger problems?
Thank you!
Ned Lloyd
Username: ned_l
Post Number: 178
Posted on Wednesday, September 26, 2018 - 12:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hmmm, .... I don't remember ever having that problem on my 109 (the gadget is the 'tac drive'.. tachometer drive)
Are you getting much blow by out of the oil fill when you remove the cap while the engine is running?
