Old 2 Cycle, 3-inch bore Marine Engin...
Old Marine Engine » Unknown Engines - post here with photos » Old 2 Cycle, 3-inch bore Marine Engine (what kind? year?) « Previous Next »
Mark Lovmo
Username: dperdue
Posted on Sunday, July 29, 2018 - 12:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What kind of marine engine is this? What application was it used, and what period of time was it made?
Would like to know what I have here....
Jim Parrott
Username: jim_parrott
Post Number: 191
Posted on Sunday, July 29, 2018 - 10:19 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mark,
Try posting some more pictures to cover the rest of the engine.
Jim
Bruce Hall
Username: bruce
Post Number: 655
Posted on Monday, July 30, 2018 - 07:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
missing a water pump-carb substitution ??
miro forest
Post Number: 986
Posted on Thursday, August 02, 2018 - 09:43 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It was likely made in the 1910 period - may not be a marine engine because it does not have an eccentric for a water pump, plus its base would place it quite high up in the hull.
It was likely an engine used to power a water pump and got its cooling water from the big pump.
But it could be a derivative of a marine engine or the other way around.
It probably had a Schebler 1 in. carb originally.
Richard D or Ernie should be able to narrow the ID of the engine, if derived from a marine engine.
