China prototyping suppliers
Old Marine Engine » Multi Cylinder Gas Inboards » China prototyping suppliers « Previous Next »
zhebaby0721
Username: zhebaby0721
Post Number: 27
Posted on Wednesday, July 18, 2018 - 10:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Stereolithography
For rapid prototypes and low-volume production, we offer stereolithography (SLA) and selective laser sintering (SLS) of plastics as an additional option to 3D metal printing (DMLM).
Stereolithography (SLA)Starting from a 3D image, a part is built slice by slice from bottom to top in a vessel of liquid polymer that hardens when struck by a laser beam.For Mastars, it started in 1998 with the RP technology stereolithography. Stereolithography is now one of the most widely used rapid prototyping techniques for plastic models.
Starting from your STL file, the required supports for overhangs and cavities are automatically generated in the model under construction. The support and model files are then "cut" into thin horizontal slices and programmed into the stereolithography 3-D Printing machine.
This machine then uses a computer-controlled laser to draw the bottom cross section onto the surface of a liquid polymer that hardens where struck by the laser. The part is then lowered to a depth corresponding to the section's thickness and the next cross section is then drawn directly on top of the previous one. This is repeated until the part is finished. The supports are removed manually after the product is taken from the stereolithography machine.
Tolerances
SLA and SLS models typically have layer thicknesses of + .3mm with a lateral deviation of + .1mm. Better tolerances than this can easily be achieved with post machining per customer requirements. Please see here for more information on the tolerance guide for plastic materials.china prototyping suppliers
website:http://www.mastarsgroups.com/rapid-prototyping/
