Type 51/2 HP
Old Marine Engine » Ferro » Type 51/2 HP « Previous Next »
kevin lang
Username: klanger
Post Number: 133
Posted on Thursday, August 01, 2019 - 07:57 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I now have 2 51/2 hp Ferro engines.
1 is a marine engine, the other was a stationary engine.
Would they be both type E?
The marine has a tag with Type E on it.
The stationary is without a tag.
kevin lang
Username: klanger
Post Number: 134
Posted on Thursday, August 01, 2019 - 08:09 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The marine engine has a magneto fitted, large Schebler carby and has suffered the salts bad.
kevin lang
Username: klanger
Post Number: 135
Posted on Thursday, August 01, 2019 - 08:19 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The stationary engine.
Has a magneto fitted, Ferro oiler, Ferro carby, water pump with strap, governor with linkage to carby and a long shaft out the back of the engine.
