Please help identify this engine
Old Marine Engine » Unknown Engines - post here with photos » Please help identify this engine « Previous Next »
Lyle Nelson
Username: maytag
Posted on Wednesday, April 25, 2018 - 05:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
No markings, no water pump, missing timer.unknown engine 1Unknown 2
miro forest
Post Number: 967
Posted on Wednesday, April 25, 2018 - 08:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It may not be a marine engine - the shaft on the exhaust side is off the camshaft - turning at half engine speed. This is where the timer would have been.
The shaft on the other side looks awfully long for a marine engine.
And in any case the engine would be mounted way up in the air if it were installed in a small boat.
It's probably a water pump engine.Cooling water taken from the output of the main water pump - no need for a second pump on the motor.
But no question that it is an early 1900's engine - the mixing valve and the atmospheric intake valve are the indicators of the age. It's probably about 2 HP at 800 RPM - doesn't look abused.
Lyle Nelson
Username: maytag
Posted on Thursday, April 26, 2018 - 11:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks, Miro! Yeah, there is no governor, so it must have been a constant load application. Water pump fits that.
