Perkins 4108
Old Marine Engine » Diesel Inboards » Perkins 4108 « Previous Next »
ratboy
Username: ratboy
Posted on Wednesday, December 13, 2006 - 04:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
new here need help
where is the oil pressure sender on a perkins 4108. thanks
IAIN MAC
Posted on Thursday, April 05, 2007 - 09:09 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
PLEASE COULD SOME ONE TELL ME WHAT GRADE OF OIL I SHOULD USE FOR MY MARINISED 4108 ENGINE AT THIS TIME OF YEAR - THANKS
larry_from_maryland
Username: larry_from_maryland
Post Number: 229
Posted on Thursday, April 05, 2007 - 12:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The new recomomdation is 15w40 diesel engine oil. Use this all year round.
bobsnads
Username: bobsnads
Posted on Saturday, July 21, 2007 - 05:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I there a trick to removing injectors from a Perkins 4-108? Any help is apprciated.
Bob
larry_from_maryland
Post Number: 255
Posted on Sunday, July 22, 2007 - 10:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If you have the standard cav injector with 2 nuts to remove just pry up on the ears. If you have the pencile injectors with one nut holding it in,you can have problems. Carbon can leak around the seal at the bottem and lock it in. I was told to use a ladyslipper tool to remove them if tight. However in one case i had to remove the head and drive out from the bottem. You need a special punch that only pushes on the outside of the injector tip to do this or you will make things worse.
mike mullen
Posted on Tuesday, May 05, 2009 - 02:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I NEED A USED, OR REBUILT DUAL OIL COOLER FOR A PERKINS 6-354T RANGE 4. CAN ANYBODY HELP ME. THANKS, MIKE
larry_from_maryland
Post Number: 356
Posted on Tuesday, May 05, 2009 - 07:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I 'am guessing you want a water to oil cooler. The older engines used a cylinder type heat exchanger. The surplus center used to have them, now they have mostly air oil coolers. A lot of the newer engines had coolers in the radiator and they have much larger oil lines going to them. You could try valu-bilt.
manatee_84
Username: manatee_84
Posted on Sunday, March 21, 2010 - 12:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I need some help/advise regarding a 1984 vintage 4-108 new to me last spring. This past winter I updated the fuel filtration system with two racor filters (the small ones with spin-on cartriges and settling bowls below). I also removed a number of ball valves and copper tubing since it was an overly complicated system that has a genset and diesel fireplace added over the years. The GenSet and fire place work, but I am having problems with the Perkins.
One of the things I replaced was the leaky hose assembly from the copper fuel lines to the engine and the return hose assembly from the engine to the copper. Since these assemblies are no longer available, I created my own with Coast Guard approved hose and 1/4 inch steel tube with copper farrels. I took the threaded fittings off the old assembly. If I could get thread to barbed hose fittings, I would just route hose directly to the primer pump.
When I attempt to purge the air from the system, the primer pump makes squirting sounds and I am not sure if this is normal or if I am sucking air or there might be a pin-hole in the diaphram.
So here are a couple of questions:
Should there be some sort of rubber gasket/washer on the end of the 1/4 in fuel line where it attaches to the primer pump?
How do you get to the fittings on the injector pump? It is covered by the heat exchanger.
Has anyone found thread/barbed fittings to connet the fuel hose directly to the engine?
One of the fittings I removed during the upgrade looked like a small check valve. Is this a piece that is required to be in the system just ahead of the primer?
Is it advisable to install an electric lift pump? This is what I had on a previous boat with a Westerbeke.
Any advise would be appreciated. I doubt there is a Perkins Marine mechanic within three or four hours drive time, so I am pretty much on my own.
Steve
Kennewick, Washington
larry_from_maryland
Post Number: 390
Posted on Sunday, March 21, 2010 - 12:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Without seeing the fitting you have its hard to tell. Vintage stuff often used wipp fittings to attach the fuel line. They used a rubber washer inside to help absorb the vibration.Not all used this type. If the diaphram has a hole the engine will fill with fuel. If most of the system is dry you should hear it pumping, but from what your saying probably have a leak somewhere. If you changed the filters you need to bleed the injector pump.The primer pump should have built in check valves, sometimes you see extra ones added.An electric pump works great you can turn on the pump and fill everything without cranking the engine. You need a pump that makes around 10 psi. Parts places try to sell what they have in stock and now they stock high psi pumps for car injector systems.Some perkins systems have a restrictor/ check valve hooked above the filters which is supposed to bleed off small amounts of fuel /air and send to the return line.If i could see the stuff i might be more help.
matt_morehouse
Username: matt_morehouse
Post Number: 38
Posted on Sunday, March 21, 2010 - 02:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I had a Freya 39 with a Volvo MD17C. I replaced all the copper fuel lines with Aeroquip fuel line, added a Racor filter and a 12v automotive fuel pump. The electric fuel pump completely eliminated bleeding hassles.
I also removed the mechanical lift pump and covered the opening with a plate. I don't recall how I mated the Aeroquip stuff to the engine but since I can't recall I guess it wasn't a problem. After this refit I never had another fuel problem
That engine and fuel system used banjo fittings. If you (or anyone else) needs banjos let me know I have a mess of them.
manatee_84
Posted on Sunday, March 21, 2010 - 11:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Larry and Matt,
Thanks for the replies. I spent a few hours today trying to bleed the air from the system. No success yet. I appreciate the offer on the banjo fittings - the perkins has quite a number of them and all appear to be in fine shape.
In trying to resolve my issue, I went back to the parts book for the Perkins. There are a significant number of washer/bushings noted as "olive". My Westerbeke and farm tractor experience has not encountered this part name. Can anyone fill me in on exactly what an olive is?
I think air is entering the fuel line at the lift pump. Until I resolve that issue, I doubt that the engine will start.
I will drop down to the boat this week and take a couple of photos so you can give me more clear advise.
Rich marine
Posted on Tuesday, September 28, 2010 - 04:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have a look here, olives
http://en.wikipedia.org/wiki/Compression_fitting
AC Grimwade
Posted on Monday, October 17, 2011 - 04:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I over heated my Perkins 4.108 yesterday. Long story short when I was idling it to cool. I was infact making it worse as the coolant had leaked out. There were no scary sounds, she just petered out. Now she won't start. She turns over, she has fuel (I bled the lines just in case), she has coolant and the coolant leak fixed, but doesn't seem to manage enough compression to start up.
The oil looks ok (not milky), and the coolant level is maintaining. What should I do next? If I had blown the head gasket wouldn't there be some kind of sign?
oslin04
Username: oslin04
Post Number: 62
Posted on Tuesday, October 18, 2011 - 05:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi AC Grimwade,
Re the over heating of your perkins, it is possible you have a degraded head gasket and or over heated the rings but, I would first of all remove the injectors and put about half a egg cup of engine oil down each bore, roll the engine over a couple of times and replace the injectors and try for a start, it may just be dry bores again due to the over heating if you are lucky,
be lucky
Regards Keith Inglis. Marine Engineer
terryf
Username: terryf
Posted on Saturday, November 05, 2011 - 06:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi can anbody please help me I have a cruiser with a Perkins 4108 in. I took the injectors out to clean wish I didnt, when i refitted them one of the couplings that hold them in place broke then i actually noticed that two others had slight cracks in them. does any one know where I could get replacements. Please help
big_e
Username: big_e
Posted on Monday, February 20, 2012 - 01:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello: Have a buddy stuck down in Cabo with a Perkins 4108 problem. He had to re4place the injector pump. I've pasted his remarks below and am looking for advice to help him.
"Perkins 4-108, it runs but every once in a while it makes a loud clang
noise. If I loosen the input to each of the four injectors one at a
time it stumbles a little which tells they are all firing. It can go
for a while but then it clangs again. I don't think anything is broken
inside yet or it would be clanging more often or all the time."
Has anyone heard this before?
Big E
Dennis Lloyd
Posted on Wednesday, September 12, 2012 - 12:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
water leak in perkins 4108 marine engine. replaced water pump and hoses still leaks but no signs of any water leakage. i have to fill up with about 2 litres each morning after using the boat. No water in the oil. any ideas
oslin04
Username: oslin04
Post Number: 66
Posted on Wednesday, September 12, 2012 - 01:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Big E, I suggest you have some air going through an or all the injectors, check all the pipe fittings paying attention to any over tightened fittings/olives and pipes, which can give you a slight air leak on the suction side of the pump back to the tank, if it was on the pressure side you would see it.
Dennis Lloyd, re your water leakage it might be a head gasket do a compression test and see if one is down, with the absence of any external leaks you must look to the gaskets, also I take it you have checked the water pump seals and you are not getting a higher level in the sump pan?
if you are not then the water must being going somewhere, could be being burnt off on the head if the gasket is gone and leaking in to the combustion chamber?
hope this helps :-)
Keith Marine Engineer.
Charles Wayne Purdy
Posted on Wednesday, September 12, 2012 - 05:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Just a note on the multi weight oil.
Some of the older engines do not like it. In some cases they will slobber on it.
I was going to rebuild an engine and asked advice of a mechanic on having it done. Told him what was going on. He asked if I had changed from the 30 weight oil to munti grane and on my saying yes he told me to change it back and in a few hours all would be well. Several 100's of hours later the engine is still going strong and no slobbers.
mooreabc123
Username: mooreabc123
Posted on Friday, November 08, 2013 - 10:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi, can anyone tell me what size the copper pipe is that runs in front of my perkins 4108 for the fresh water cooling
Leon Baldridge
Posted on Wednesday, October 28, 2015 - 01:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a perkins 4108 1972 in a military wale boat it is leaking oil and water I need to find a new or used replacement there is no water in oil. can anyone help ?
Leon Baldridge
Posted on Wednesday, October 28, 2015 - 02:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I forgot to mention the water leak is coming from the oil cooler. I had it worked on and the man who worked on it did not back up the nut that is welded on the side of the cooler. I'm in the US and the boat is in Honduras. Big problem
howardeisemnn
Username: howardeisemnn
Posted on Saturday, March 12, 2016 - 08:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Perkins 4108. Evidence of engine coolant collecting at the base of the #1 fuel injector. Coolant level does not seem to be affected and no overheating. Engine starts and runs fine. Block test for combustion gas at expansion tank fill does not indicate and carbon dioxide. Realize possibility of head gasket/head crack but have not taken head off yet and would rather not if any alternatives are available Any suggestions, recommendations would be appreciated
w_wier
Username: w_wier
Posted on Thursday, May 12, 2016 - 08:47 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello Folks. Thought by chance, since there is a lot of activity about the 4-108 engine I would ask if anyone knows of a Paragon P220 gearbox hanging round. I'm resurrecting a US Navy whale boat and I'm missing one to fit up to the Perkins 4-108.
Need the proper propeller also. Bill
oslin04
Username: oslin04
Post Number: 90
Posted on Thursday, May 12, 2016 - 12:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I would not waist your time with a Paragon gearbox, what you need is a PRM 100 which you can get parts for and is a much better box all round with a get you home gear lock in if the hydraulics fail which I have never know to happen.
w_wier
Username: w_wier
Posted on Thursday, May 12, 2016 - 06:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank you Keith for the recommendation. I need a 4" centerline drop @ about 40hp for a proper fit up. I'll check the spec's for the PRM box. Cheers
CaptainRobb
Posted on Thursday, May 17, 2018 - 02:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Westerbeke w40
I have a W40 that I bought and we are checking the compression and getting about 300 psi in all cylinders with all injectors removed during cranking. Is this within normal range?
