I am looking for part's please
Old Marine Engine » Boats with Early Inboards » I am looking for part's please « Previous Next »
harley
Username: harley
Posted on Sunday, March 18, 2018 - 07:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi I am looking for part's and information on this motor I am trying to restore, this use to be my Grandfather motor.
Post Number: 960
Posted on Sunday, March 18, 2018 - 11:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks like you have the timer and the water pump with the eccentric shaft- they're the more challenging parts to find.
It probably used a Schebler Model D carb - my guess would be a 1 inch or maybe 3/4 ( the more difficult to find)
The buzz coil probably might need a new capacitor - a bit of excavation will be needed to get the old one out . Or make up a modern version of the coil.
My guess is that it is earlier than 1905/7 because of the mounting flange - it's below the mid level of the engine crankshaft.
Assuming that it is not stuck and has a bit of compression, it might start OK.
A couple more pictures - front, side, rear and some close ups will greatly assist in figuring out what it is.
But it looks like a good "find" for the group here.
Post Number: 2454
Posted on Monday, March 19, 2018 - 05:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It is a Caile Bantam.
Take a look here
http://www.oldmarineengine.com/discus/messages/3454/4991.html
I have one if you need more pics.
Hope this helps
