Help with rare Paragon marine transmi...
Old Marine Engine » Gears, Transmissions, and Propellers » Help with rare Paragon marine transmission HF AB2-L « Previous Next »
Jim Close
Username: aussiejim
Posted on Tuesday, February 13, 2018 - 04:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am trying to find out about the following paragon gearbox that is connected to a Volvo Penta MD32A 108hp 6 cylinder marine diesel engine:
� I am trying to work out how to set-up and were to connect the hydraulic cooling system which is the inlet and outlet?
� Best Mounting system as there are no side mount bolt holes for a support bracket for it.
� I cannot find any info on this model as it is unlike any model that I have seen, would you have a manual/drawing for it?
� Any help would be much appreciated.
� I have attached a pdf with photos of the setup.
PARAGON name plate fwd:
Reads:
HYDRALIC REVERSE GEAR
Us trans TYPE A
Model: HF AB2-L
Serial no. 4P2710
Patent 269435
Paragon gear name plate aft
Model: RB20-R
Serial number: 4M2837
Best regards,
Jim Close
HF AB2-L Paragon
