Post Number: 293 Registered: 07-2002
| Posted on Monday, October 15, 2007 - 08:39 pm: |
Keith Dupuy picked up this engine today, it's a nice complete early engine, was stuck but broke loose and turns half a round. The most distinguishing feature is the timer shaft running through the water pump, also means the water is being introduced to the top of the cylinder. No tag, any ideas?
Post Number: 736 Registered: 01-2002
| Posted on Tuesday, October 16, 2007 - 08:09 am: |
IT's a Waterman Dick Day has one. They run real nice |
keith
Senior Member Username: keith
Post Number: 185 Registered: 02-2002
| Posted on Tuesday, October 16, 2007 - 11:08 am: |
Looks like it has a $200 Crown Rod Oiler on it |
Post Number: 737 Registered: 01-2002
| Posted on Tuesday, October 16, 2007 - 06:39 pm: |
Here are pics of Dick Days Engine Note the added counter balance on the flywheel. I didn't get a pic of the tag. It is about 1 inch round on the back of the cylinder. |
Post Number: 294 Registered: 07-2002
| Posted on Tuesday, October 16, 2007 - 08:37 pm: |
Thanks Ernie, looks like it. Different timer and Keith's has a bushing on the spark plug. Do you think the bushing was to allow a boring bar to pass through for cylinder machining? |
Post Number: 295 Registered: 07-2002
| Posted on Tuesday, October 16, 2007 - 08:39 pm: |
The oiler looked strange to me Keith, I'm not familiar with rod oilers but it would make sense. The sloshing action of the rod would allow it to work. |
Post Number: 738 Registered: 01-2002
| Posted on Tuesday, October 16, 2007 - 09:07 pm: |
JB, I don't remember, however I think Dicks has a bushing on the plug too. Makes sense to support the boring bar. I also seem to remember the timer cover on Dicks says Waterman on it as well. Dick? |
Post Number: 1551 Registered: 11-2001
| Posted on Sunday, October 21, 2007 - 10:26 am: |
* Keith, I think that you have found a rare classic old marine engine here and it seems in good original condition ! Thanks Ernie for the I.D. and photos of Dicks engine ! When J.B. posted the photos above I knew I had seen this engine but didn't have a name for it. Around the turn of the century E.W. Roberts was probably the most prolific designer and writer about the two cycle marine engine, he claims to have designed well over 100 different engines before establishing his own mfging Co. in 1906. I have always wondered where are all of these engines and what did they look like, and who mfgd them ? I believe that this Waterman is one of those ! Roberts designed engines of this time had the water/pump mounted near the top front of the cyl with the timer shaft going through it, the cylinder, cylinder flange, upper crank housing appear to be very similar casting. this 1907 photo ad with exceptions of lower crankcase, and intake and ex manifolds look similar ? Cameron Waterman designed his Porto out board and mfgd it in 1906 his early ads said inboard engs were also available but I have not found a photo ad or catalog yet showing these engs or any reference to who may have actually Cast or mfgd them. Later inboards sold by Waterman were the much more well known copper jacketed two cycle like the Arrow or dispro etc ?? Nice Find !!! * |
Post Number: 740 Registered: 01-2002
| Posted on Sunday, October 21, 2007 - 04:39 pm: |
The timer water pump is the givaway to a lot of EW Roberts designes. Bruce Stewart Imparial from Prince Edward Island, NS Mullins Roberts And at least one more that I can't seem to remember right now. |
Post Number: 741 Registered: 01-2002
| Posted on Sunday, October 21, 2007 - 04:48 pm: |
Here is the tag from Dick's Engine The tag is 1-9/16” diameter.
Post Number: 298 Registered: 07-2002
| Posted on Sunday, October 21, 2007 - 08:08 pm: |
Thanks for the info Richard & Ernie. Keith had his engine at a local show today, cranked it off for the first time. It ran well, starts and reverses easily, idles slow. A look at the pictures and you see the disadvantage of the front water pump, you can't hold the flywheel to pull it through compression. Dick Days motor seems to have more room Ernie, do you think the replacement gear had a thicker hub? |
Post Number: 742 Registered: 01-2002
| Posted on Wednesday, October 24, 2007 - 11:44 am: |
JB, This engine was so scewed up as far as the timer goes I have no idea what might have been. The timer gears are something that Dick got from George King. There was nothing there to start with. Going by the water pump eccretic strap I moved the flywheel closer to the engine. I had to bend it to line up properly. I do remember the crank gear had a long hub on it. I also had to cut the center out of it to get it close enough to the engine to have proper mesh with the timer gear. On Keiths engine is the eccretic part of the gear or the flywheel? Dicks engine is part of the flyweel. Hope this helps E |
Post Number: 1573 Registered: 11-2001
| Posted on Wednesday, November 14, 2007 - 09:43 am: |
* Another log on the fire! When you think you have some of this Old Marine Engine history figured out it is probably an Illusion -- most of the time a disillusionment!! Here's a 1908 Waterman ad That shows a model X improved KOWALSKY engine and that it was formerly made at Verona, Pennsylvania ?? Did Waterman buy out Kowalsky ?? Look at the casting on this twin it sure looks like the above engs. Kowalsky was one of those turn of the century brilliant inventors who among other things designed several different marine engs by this 1908 date ??? Is this his design or E.W. Roberts ?? * |
Post Number: 761 Registered: 01-2002
| Posted on Wednesday, November 14, 2007 - 08:03 pm: |
Richard, The pic above is definatly a Roberts design. Kowalsky engines didn't look anything like a Roberts design. So I wonder if Roberts was designing or allowed the use of his designs by Kowalsky before the purchase by Waterman??? Take a look here for some Kowalsky pics |
Post Number: 1574 Registered: 11-2001
| Posted on Thursday, November 15, 2007 - 06:34 pm: |
* Ernie Thats the way it looks, still looking into who actually made these engines ?? * |
Post Number: 762 Registered: 01-2002
| Posted on Thursday, November 15, 2007 - 08:17 pm: |
Richard, I think the key is who did E.W. Roberts work for. HeHe maybe both... Also I am quite sure Waterman was around with Roberts style engines before they had the official dealing with Kowalsky. Maybe chase it from that angle??? |
bgoss
New member Username: bgoss
Post Number: 2 Registered: 12-2007
| Posted on Monday, December 10, 2007 - 07:37 pm: |
Thanks for the info, I think that helps to identify one of ours. Other than the pouring plugs being in different locations on the cylinder, everything else seems to match the Waterman's pictured above. Thanks again
philg
Member Username: philg
Post Number: 5 Registered: 02-2008
| Posted on Sunday, April 13, 2008 - 09:29 pm: |
Hi Guys, was surfing this site and followed a lot of links to Waterman engines and Robertson designs. I have a small engine that seems to be very similar to the Waterman, only it has a split crank case. It did come with a Breezee carb and looks very similar to the Waterman outboard that converts to a stationary in Wendels BYB, I think Waterman used the Breezee around 1910? My pics show a second breezee with a check valve but no provision for an oiler. On the top of the cylinder it looks like something has been removed and a plate welded in, any ideas on what's missing? The back of the engine there is a machined area that could possibly hold a water pump(missing). 2 owners previous to me had the engine running to pump water to his garden from a ditch, using a belt drive to a gear pump and bled off water from it to cool the engine. |
Post Number: 357 Registered: 07-2002
| Posted on Monday, April 14, 2008 - 09:20 pm: |
Is it possible that the cylinder was rotated? That could be a water pump mount-inlet if it were in the front. Look through the exhaust with the piston down and see if the deflector on the piston is in front of the transfer port on the opposite side of the exhaust. If the cylinder was out of rotation, the deflector and transfer port would be in the front of the engine as in the picture above yours. |
Post Number: 1684 Registered: 11-2001
| Posted on Tuesday, April 15, 2008 - 07:42 pm: |
* I have been trying to I.D. this one by the vertically split crankcase but no matches yet ? This one will stay in the Unknown engine file for now ! * |
philg
Post Number: 6 Registered: 02-2008
| Posted on Sunday, April 27, 2008 - 08:55 pm: |
Hi Guys, with JB's suggestion that the cylinder may have been rotated, I pulled the jug off- and what a surprise! Someone has been fiddling in here already, the cylinder can not be rotated because the transfer point needs to line up on the base, the bolt holes are 3" one way by 3.25" the other so as to not mix them up. If it was rotated a full 180 degrees the carb would interfere with the flywheel and the transfer port would not connect properly with the base. The big surprise was that the baffle has been sawed off and a new one added, but it is now positioned just inside the exhaust port. I have attempted pictures to show you what I mean. I believe the piston has been changed because the original baffle would not work even if turned around. I'm interested on anyones take on what this engine is or why these changed were made? |
john_archibald
Senior Member Username: john_archibald
Post Number: 59 Registered: 08-2006
| Posted on Sunday, April 27, 2008 - 10:32 pm: |
It would appear that someone found a used piston that fit, but that the baffle was missing or was off by 90 degrees and they cut it off...maybe? In order to make it work they fastened on a homemade baffle, but got it 180 degrees off! It should be blocking the intake ports. You may wish to check if the rings interfere with the ports. Make sure that there are no joints / ring gaps crossing the ports. The rings should be "pinned" or made "captive" so that they cannot rotate about a vertical axis. Move the homemade baffle to the other side and the engine will work a lot better! Archibald Northfield, Minnesota . |
jim_parrott
Senior Member Username: jim_parrott
Post Number: 165 Registered: 06-2009
| Posted on Sunday, January 21, 2018 - 08:38 am: |
A couple years ago, I purchased a Waterman A4 thinking it was a John Kowalsky design. Below are a few links mentioning the Kowalsky/Waterman connection. Definitely some similarities. http://www.veronahistory.org/john-kowalsky.html http://www.coolspringpowermuseum.org/Publications/Flywheel/Flywheel_201505.htm http://www.coolspringpowermuseum.org/Publications/Flywheel/Flywheel_201507.htm |
