boatgirl
New member Username: boatgirl
Post Number: 1 Registered: 07-2004
| Posted on Tuesday, July 27, 2004 - 01:21 pm: |
My boat has a grey marine flathead 4 cylinder engine and I am trying to determine what model it is...the little plaque is not there. I've seen the sea scout and it isn't that one. Some questions: 1) If I want to get an operator's or maintence manual, do I have to know the model of my engine or are all grey marine 4 cylinders basically the same? The website I found with manuals doesn't distinguish between models but I want to be sure before I buy. 2) Can I use the casting number to find the model? 3) I think I am having generator problems, but all the marine mechanics books I find talk about alternators and what proper output for alternators should be...does anyone know where I can find info about generators? Any info is appreciated. |
larry_from_maryland
Post Number: 153 Registered: 07-2003
| Posted on Tuesday, July 27, 2004 - 02:31 pm: |
If your distributor sticks strait up through the head and you have a casting number that starts cw or cwc then you have continental F series engine,either 124,142 or162 ci.If you have any csating numbers post them and someone will id it. |
Paul Visitor
| Posted on Wednesday, July 28, 2004 - 08:07 am: |
The manual I have for my 25Hp 4cyl is the same booklet for about 6 other models. There are a few places where alternate information is provided for the different groups of engines, and the specs are listed in tables, but the operation and maintenance are basically the same. |
boatgirl
Post Number: 2 Registered: 07-2004
| Posted on Monday, August 16, 2004 - 12:45 pm: |
ok, finally...the casting number is Y400 A418. I have a maintenance and parts manual for a Sea Scout-91, which is extrememly similar, but not exactly like my engine. The location (or presence) of an oil filter being the main difference so far. I also found a model and serial number on the transmission (Paragon: "Made exclusively for Grey Marine...") Model RDBS-7, #F-5951. Does any of this info tell us what the model of the engine is? Also, the water pumps that I have are Jabsco Model B. (One is engine cooling, the other is wet exhaust). None of the guys in any of the Jabsco vendor repair shops have a clue about it. We fitted a new impeller based on the current (maybe recently obsolete) pump that is most similar to mine. It looks and measures identical to the impeller I removed from the pump. Now water is leaking out the grease cup threads unless I screw the cap down really tight and then the water leaks out the shaft, which I am pretty sure it should NOT do. The water coming out the shaft feels hotter than the water that went through the engine already! Does anyone have a suggestion on what could be the problem? |
larry_from_maryland
Post Number: 156 Registered: 07-2003
| Posted on Tuesday, August 17, 2004 - 08:35 am: |
The Y series of continential engines were made in 69,91 and 112 cubic inches.With a Y in the casting number i would think its one of those three.On the outside they look much the same,but can have differances depending on age and where they are installed.The oil filter is one part that was upgraded and changed over the years. |
l_ee_waddell
New member Username: l_ee_waddell
Post Number: 1 Registered: 08-2004
| Posted on Saturday, August 21, 2004 - 03:21 pm: |
Does anyone know where I can get impellers for a grey marine cold water pump used on a 1941 671 detriot? |
tj36 Visitor
| Posted on Tuesday, September 07, 2004 - 08:08 pm: |
I HAVE A GRAY MARINE ENGINE IN MY DOZER AND WOULD LIKE TO REBUILD IT. THE ONLY THING I SEE ON THE BLOCK IS CWC. CAN SOMEONE HELP? |
Moderator Username: andrew
Post Number: 885 Registered: 11-2001
| Posted on Tuesday, September 07, 2004 - 08:23 pm: |
TJ36, You might have to provide some more info... Is it gas or diesel? How many cylinders? Is there another tag with a model number or serial number? How do you know it is a Gray Marine Engine? Do you know the bore & stroke or displacement? Approximate year of manufacture? If it is a gas engine it is probably a Continental block. If it is a diesel it is probably what became the 71 series Detroit Diesel engine. |
tj36 Visitor
| Posted on Tuesday, September 07, 2004 - 09:18 pm: |
andrew' gray marine is stamped on the block. the engine is a 4cyl gas. there is no other tag or number that i can or my buddy can find. that all i know about it. |
larry_from_maryland
Post Number: 167 Registered: 07-2003
| Posted on Wednesday, September 08, 2004 - 12:33 pm: |
CWC is very common on continential engines.If you have a distributer comeing straight up out of the head its an F series either 140 or 162ci.They are a common replacement for bad engines in massy harris,cletrac,oliver and silverking tractors.There is one of thease in the drake tail work boat at calvert. |
tj36 Visitor
| Posted on Wednesday, September 08, 2004 - 06:52 pm: |
larry, where can i get a rebuilding kit? thanks tj |
Phil with century-viking
| Posted on Monday, September 13, 2004 - 02:32 pm: |
Mine is a Gray marine engine in a 56 Century; 4-cylinder, model 620. I am having big trouble getting the thing to idle properly --once I put it in gear, it stalls unless the idle is set at screaming. Had the carb off a few times and cleaned it out as best I could and think that all passages are clear, etc. Someone mentioned timing as a possible problem. Does anyone have any info on how to set the timing, idle RPMs, points, etc., on this thing --or any other ideas on what may be wrong? Thanks |
Post Number: 899 Registered: 11-2001
| Posted on Monday, September 13, 2004 - 11:25 pm: |
The Gray Marine Maintenance Handbook would have those settings. |
James H. Godbee
| Posted on Friday, January 07, 2005 - 03:24 pm: |
I have a complete gray marine engine, transmission, driveshaft, propshaft, everything Model 620, engine #F11898. When removed from old boat, running good. Been setting up for 10/12 years. Take $500.00 or value in trade. No manual or papers must have been made in the 40's not sure. |
Post Number: 1012 Registered: 11-2001
| Posted on Friday, January 07, 2005 - 07:23 pm: |
James, You should post it for sale in the classifieds section. |
tod wagner
| Posted on Saturday, April 09, 2005 - 12:13 am: |
i have a continential 4 cylinder liquid cooled engine cwcreg-1 8 or b156 casting #i bought on ebay it has a generator on it and i want to use the engine in a sae5 application to run a simon trailblazer40 ariel lift the index sizes on the flywheel are different i need to install an 8 inch coupling plate and the continential engine i have has only 7 inch center of flywheel maybee it can be machined or may need a bifferent flywheel if anyone knows the info i need it would be appriciated [email protected] |
John Starke Sr.
| Posted on Thursday, March 20, 2008 - 10:20 pm: |
Hello; I have a phantom 462, running, that belonged to my late dad. I also have the owners handbook. Boats are one of my hobies. (spelling is not!) I have a 1969 Pearson 28' cabin cruiser inboard that had a V8 (gas hog) in it. I am thinking about putting the phantom in it. It does not have the reduction gear in it. I am considering using a 13x8 prop to obtain a simi-plaining gas sipper. Anyone have any thoughts, ideas, comments, trades, etc? John |
Daniel J. Heaney
New member Username: blue_heron
Post Number: 2 Registered: 01-2009
| Posted on Sunday, January 11, 2009 - 01:57 am: |
Where can I find parts and gaskets for a Grey Marine Model 70 Thanks, |
james baron
New member Username: baron6405
Post Number: 1 Registered: 01-2009
| Posted on Wednesday, January 21, 2009 - 09:48 pm: |
looking for a gray racing 4 135cu in or a universal blue jacket racer with gear box would be nice grandfather was building "flyer hydroplane" but passed away i want to finish but need motor and gear box to continue |
Fred MCbride Visitor
| Posted on Friday, February 06, 2009 - 08:51 am: |
I have a 1990 Larson with a blown 5 liter Merc Cruiser engine on a I/O Alpha I outrive can I replace the engine with a 4 cylinder Marine engine? |
Roger DiRuscio
Post Number: 347 Registered: 03-2002
| Posted on Friday, February 06, 2009 - 01:14 pm: |
why would you, wouldn't there be a huge horse power loss??? |
Andrew Hill Visitor
| Posted on Wednesday, June 10, 2009 - 07:23 am: |
Trying to find out information on 1924 4cylinder grey car engine. Does anyone know were i can get some information or identify this motor?? Is it similar to the marine engine? Any help would be greatly apreaciated. |
Frank Petran
Advanced Member Username: frank_petran
Post Number: 33 Registered: 05-2009
| Posted on Friday, June 12, 2009 - 07:36 am: |
Contact David Van Ness Engineering, 252 Lincoln Avenue, Ridgewood, NJ 07450. 203-445-8685. He is probably the most knowledgeable person for 4, 6, and 8 cylinder 4 cycle engines. Has parts, engines, literature. He is heavy into old wood boat Gray engines. Tell him Frank Petran recommended him. Frank Petran |
Graeme Chimes Visitor
| Posted on Thursday, July 02, 2009 - 11:52 pm: |
Can anybody tell me the weight of the 25hp Grey, 112ci model. |
Jim Staib
Member Username: drrot
Post Number: 27 Registered: 09-2008
| Posted on Friday, July 03, 2009 - 07:45 am: |
My book list the 25hp as 91" and 390lbs direct drive or 420lbs with reduction. The 112" is listed as 31HP and 400lbs direct drive 425 with reduction. |
kelly chambers
| Posted on Friday, September 27, 2013 - 03:28 pm: |
I have a greys marine v8 gas engine from a cabin cruser looks like a chrysler model bore is4" stroke is 3.50" engine no.# 3166463, head no.# is 3166452 would like to know the specs. and if its worth any thing block is broken from freezing but heads have been reconditioned i have most of what is still good that was attached to the motor including the outdrive which is a reduction drive. |
Allen Edwards
New member Username: allene222
Post Number: 1 Registered: 10-2013
| Posted on Tuesday, October 22, 2013 - 07:02 pm: |
I have a Gray Marine 4-112. My normal operating RPM is about 1200. With the engine hot, the oil pressure is about 20 pounds. 35 when cold. The manual says normal is 30 to 40 but doesn't specify the RPM. Says less at idle is OK. I get 15 pounds at 600 RPM hot. I am wondering if I am in the normal range with just 20 pounds at 1200 RPM. The engine has 50 hours since the rebuild. |
James Bentson
| Posted on Tuesday, June 03, 2014 - 01:21 pm: |
I have a Sea Scout 25 rebuilt to perfection, it runs fine but with the prop I have on teh 21 foot minitug it doesn't want to get over 2000rpm. I know I will need to trim down the prop, but want to know if anyone knows the max and most efficient RPM fro that engine. Basically looking fro a power curve/ fuel consumption torque curve overlay to determine where to run her and how far to push teh RPM. Its a drystack. I have a Yanmar replacement so anyone wanting a perfect Grey 25 e-mail me or call (949)-280-0886 |
candy
| Posted on Saturday, May 09, 2015 - 03:01 pm: |
my husband would like information on his 1955 grey marine phantom wooden boat four-75 model #f5342 we think thats the model # . and there is another # we found couldnt read first#s then there was a -12577 . 4 cylinder engine. |
Bruce Hall
Senior Member Username: bruce
Post Number: 493 Registered: 07-2002
| Posted on Saturday, May 09, 2015 - 03:40 pm: |
F pre-fix S/N engines are 1950 to 1953 |
PhilipWiacek
New member Username: philipwiacek
Post Number: 1 Registered: 05-2023
| Posted on Thursday, May 18, 2023 - 05:09 pm: |
I have a 1956 grey marine 6 cyl inboard, was wondering if anyone has had this issue, starts good runs good for an hour or so, then stalls out , i wait 10 min or so and starts back up and is find, is there a choke on this eng . or anyone an idea? |
PhilipWiacek
Post Number: 2 Registered: 05-2023
| Posted on Thursday, May 18, 2023 - 07:43 pm: |
correction its a 4 cyl 4-112 1956 Grey Marine, |
Jim Staib
Senior Member Username: drrot
Post Number: 299 Registered: 09-2008
| Posted on Saturday, May 20, 2023 - 11:04 am: |
Sounds like an ignition coil to me. |
miro forest
Senior Member Username: miro
Post Number: 1233 Registered: 11-2001
| Posted on Sunday, May 28, 2023 - 03:52 am: |
I used to have a similar engine - I found that after running for a while, it seemed to run out of fuel. After going through many gyrations, I found that the top and bottom half of the carb had loosened. There were 6 small machine screws that were very slightly loose, but just enough to lean out the mixture. I eventually got into the habit of checking the tightness of the screws several times per season. I needs a collection of slot screw drivers that allow you to reach in behind the carb. It requires a Zen approach - don't do this unless your mind is clear and relaxed |
Stan Derelian
New member Username: 500d
Post Number: 1 Registered: 07-2024
| Posted on Thursday, July 18, 2024 - 07:58 pm: |
1) Sea Scout 91 w 2:1 reduction gear. Rebuilt by VanNess Engineering for a project that never happened. 2) Phantom 4-45. Was running when it came out of boat. 3) Lugger 4-112. Was told it was running. I got it for parts. $1850 for all three. |
