rbprice
Post Number: 573 Registered: 11-2001
| Posted on Tuesday, August 15, 2017 - 08:18 am: |
Does anyone out there have a Mohawk engine with its timing gears intact. I need to reverse engineer the gears for my Mohawk and while I have the gear that is on the timer shaft I don't have the gear that is attached to the back of the flywheel. Some photos of the gears with the covers off would be great. Thanks very much. |
bruce
Senior Member Username: bruce
Post Number: 626 Registered: 07-2002
| Posted on Tuesday, October 24, 2017 - 07:12 pm: |
To repeat rbprice inquiry 15 August,2017. Does anyone other than rbprice and Steve Fox and I own Mohawk brand mid-teen Mohawk marine engines built by S-R Mfg . Schenectady NY. ?? Seeking dimensions of the timer miter gears. |
keith
Senior Member Username: keith
Post Number: 508 Registered: 02-2002
| Posted on Tuesday, October 24, 2017 - 08:53 pm: |
The ratio for a two cycle engine is 1 to 1, firing every time the piston is up. Therefore, the gear on the crankshaft and the gear driving the timer are identical in diametric pitch and number of teeth. The only variation would be shaft size and configuration. Hope this helps. Keith, |
keith
Post Number: 509 Registered: 02-2002
| Posted on Thursday, October 26, 2017 - 09:36 pm: |
Bob, If you send me your original timer gear I can probably help. Keith |
