Modern coil over plug
Old Marine Engine » Timers, Magnetos, Ignition » Modern coil over plug « Previous Next »
Post Number: 1074
Posted on Wednesday, October 14, 2009 - 10:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The more things change the more they stay the same.
Pics of plug coils from years ago. 1 coil per cylinder. These were powered and the timer gave a ground. A multi cylinder engine would be wired similar to the modern diagram below except the 3rd wire (terminal B) would not be there. The vibrator points were in the coil.
Pics from another OME post
Modern style one coil per plug the coils are powered and the PCM (engine computer)is a switch to ground just like the timer on an old engine. To clairfy if you need to just draw a 4 cylinder timer in place of the PCM.
What I need to do is tourture one and see if it will live with a long on time that an old timer gives. Also the timer will be opposite from using a buzz coil as a buzz coil makes spark when the timer turns on. These are a true ignition coils and make spark when the timer turns off. No biggy once you are used to it.
I also need to find a good way to shorten the boot as it is about 6 inches long.
Pic and diagram courtsey Mazda
Post Number: 2213
Posted on Thursday, October 15, 2009 - 06:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
1914
plug14
Post Number: 2214
Posted on Thursday, October 15, 2009 - 08:13 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Per14
Searcher
Username: searcher
Post Number: 357
Posted on Thursday, October 15, 2009 - 01:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
A couple of years ago, I caught an advertisment for a foreign car that was touting coil plugs as the latest and greatest advancement in automobile ignition. Yea, right. The Orswell Ignition System has a 1907 patent date so I guess that put Orswell ahead of the curve a century too early.
Here are four of the commonest (old) coil plugs. There were several other companies that made them as well. There aren't many old ones around as they probably never were common to begin with due to the price. A coil plug cost in the range of $8 - $9 at a time when a good spark plug could be had for $0.50.
I apologize for the poor photos. These coil plugs are really much better looking than the photos would have you believe. Clearly, I need to take a class in lighting.
Post Number: 2215
Posted on Friday, October 16, 2009 - 12:57 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
1913
pkn131
pkn131a
Bruce Egbert
Posted on Wednesday, January 24, 2018 - 12:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have a nice Connecticut Coil Plug and Samson Electric Perfex Coil plug for sale.
Call 937/446-2219 or e-mail
Thanks!
Bruce Egbert
Posted on Wednesday, January 24, 2018 - 05:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bruce Egbert
Posted on Wednesday, January 24, 2018 - 05:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
