Transmission splined drive removal
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Transmission splined drive removal « Previous Next »
William Lyons
Username: bluedevil
Posted on Friday, July 27, 2018 - 11:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am trying to disassemble a 4-75 Phantom. On the front of the crankshaft is a splined coupling then the timing gear. How do I get it off. I have removed the 1/2 x 20 bolt holding it to the crank, but does it just pull off? Don't want to break anything. Thanks in advance
Ned Lloyd
Username: ned_l
Post Number: 174
Posted on Thursday, August 02, 2018 - 05:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You really need to get your hands on (or make) a puller that grabs behind the stub shaft.
I made such a puller about 35 years ago when I needed to remove a stub shaft off a Gray 109. It is pressed on pretty tightly, so you want to remove it correctly.
