Perkins 6354 Info Required |
robbo1
New member Username: robbo1
Post Number: 3 Registered: 05-2017
| Posted on Friday, July 21, 2017 - 04:09 pm: |
I have a 1966 contra rotating Perkins 6354 engine fitted in my boat. The fresh water pump bearing failed so I removed the pump and sent it away for a rebuild as they are no longer available. Before refitting it I noticed a small crack around the bottom locating stud and a slight depression in the water exit hole near it which will leak if I reassemble everything as it is. My questions are, does the pump mount on a backing plate fixed to the front of the block or is the face I am looking at the block itself? If it is a backing plate how is fixed to the block? Does anyone have drawings or part numbers for this area of the engine as the workshop manual is a little vague? |
robbo1
Member Username: robbo1
Post Number: 4 Registered: 05-2017
| Posted on Saturday, July 22, 2017 - 04:07 am: |
This is an image of the engine area I am referring to.
